Watercooling Sound damping for XSPC bay res / pump
Discussion in 'Hardware' started by jashaf, 24 Jun 2012.
  1. jashaf
    jashaf What's a Dremel?
    20 Jun 2012
    Well I now have my HAF 932 / RIVE / Water cooled machine up and running.
    However, there is a small wine coming from the XSPC dual bay reservoir pump combo. (Here is the manual)
    If I grip both sides of the case a little on either side of the reservoir then the wind changes pitch a tiny bit and gets a bit quieter. What would be the best option to add sound damping to this bay reservoir? Any recommendations?
    (I original got the single bay res / pump combo since it simplifies the internal layout of the case. Maybe with the noise factor I should instead just go with a res top to the Koolance PMP-450 (D5 based pump) and mount that inside the case? But there really isn't a ton of spare room in there...)
    Thanks,
    Jas
