hi all just made this build, what do you think? it will be cooling 2 CPU's http://www.aquatuning.co.uk/shopping_cart.php/bkey/9b365a8131acc18fafd6cb441079f436 thanks
yeah i know theres only one, as seen as aquatuning dont have any in stock ive just realised the pump has barbed fittings so i will have to buy 2 clamps?
Did you realise the pump comes with 1/2 inch barbs, and you are using 5/16 tubing? You might be better to get the model with a D5 top, which has high flow and G1/4 threads.
http://www.aquatuning.co.uk/product...PP655----G1-4-IG-complete-with-D5-HF-Top.html or http://www.aquatuning.co.uk/product...---G1-4-inner-thread-including-Plexi-top.html Both say they are "expected", but buying the combo is easier and slightly cheaper than buying a separate top to change over (which will void the warranty), unless you are a confident modder
Apparently Mayhems Aurora is just for show and gunks up and stuff, so maybe something else would be better? Or give it a go and let us know
yeah ive read that its for show only. but it doesnt state that on there website? ive seen a couple of reviews and its been in there system for a couple on months with no issues?
