Watercooling Almost there!
Discussion in 'Hardware' started by TheRealShep, 5 Sep 2012.
  1. TheRealShep
    TheRealShep ssSSSsssssssSSSSSSSSSsss
    14 Mar 2011
    Hey guys, after reading info all over the web, I decided I had the balls to finally WC my rig fully.
    I ordered all the parts but left the reservoir till last as I have not been able to find anything online that says how to work out the best size reservoir for the amount of cooling that you want to do.
    So far I have:
    Plates-
    HDD 2x WD Cav Blacks
    GPU GTX 580
    CPU
    I was told by someone on the phone that I should just buy the biggest one that will fit in my case (I am intending to have a bay res) but I thought being serious, that could mean I could ahve about 2 or even 3 bay reservoirs and that is just way OTT.
    If anyone has an idea or even a link that I can have a look at, I would be really grateful as I can't wait to get the WC show on the road!
    Thanks in advance,
    Dan
  2. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    What case are you using? are you using a seperate pump, or looking to get a pump/res combo?
    TheRealShep likes this.
  3. TheRealShep
    14 Mar 2011
    I'm using an Antec 1200. Not sure on the pump just yet as I am aware of the combos that can be bought so I'm waiting to see what info I can get.
    I haven't thought about where I would mount a pump in the case 100% yet either, I have a few ideas but as yet I haven't made a final decision.
  4. Parge
    16 Jul 2010
    Its not really necessary to have a massive reservoir. Just get a Dual 5.25" bay one and that will be fine. If you are using a Laing DDC or D5 (and I hope you are), then some bay reservoirs allow you to mount the pump within them - which makes building your loop very easy.
  5. TheRealShep
    14 Mar 2011
    Awesome, I will have a look for a dual reservoir with those capabilities then!
    I am going for a very clean install as I spent a lot of time organising the cables so they are as perfect and in line with each other as can be! (OCD alert)
    I will get some pictures up when I get it all sorted and installed, thanks guys +1 to each of you.
    mrMonkeyChunks likes this.
  6. asura
    asura jack of all trades
    22 Apr 2009
    In truth you don't *need* a reservoir at all, they make easier filling and bleeding, but it is perfectly possible (and straight forwards) to have a loop without one, using a simple T-line, which can be as long or short as you want.
  7. Parge
    16 Jul 2010
    One of these and one of these is what I have.
    Make sure you get a molex to 4pin (PWM/Motherboard) adaptor cable so your pump doesn't run at full speed all the time.
  8. TheRealShep
    14 Mar 2011
    I like the idea of having the reservoir due to it looking smart on the front of the case too though so I will skip the idea of just having the loop on its own.
    Is there a way to control the pump using all the wiring and a control panel or is it too much hassle and should I just have it at 4-pin speed?
  9. mrMonkeyChunks
    4 Mar 2012
    I suppose you might be able to wire it up to a 4 pin fan controller and change the spped from there.
  10. asura
    22 Apr 2009
    The 35X is the only DDC which is 4pin PWM controllable. I believe AquaComputer have a PWM pump too.
    Direct voltage control works a bit, though you must be careful not to go too low and stall your pump as this will damage the pump and possibly the hardware you're cooling.
  11. Parge
    16 Jul 2010
    Oh yes, sorry, I meant 3 pin!
  12. mrMonkeyChunks
    4 Mar 2012
    as did I :duh:
  13. phuzz
    phuzz This is a title
    28 May 2004
    I've got an Alphacool AP700, and it's practically silent from outside the case, so personally I don't see speed control as being massively important.
    Of course, if you have bubbles trapped in your loop, then the pump might be noisy, and this is why you need a reservoir, it makes the whole system a lot easier to fill.
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    My D5 is silent, and its way more powerful. Only when it first starts is there any noise due to bubbles that form in it over night...
