Watercooling Radiator Size
Discussion in 'Hardware' started by 3DAM, 6 Sep 2012.
  1. 3DAM
    3DAM What's a Dremel?
    27 Jun 2012
    Would I be able to watercool my build with one radiator? Trying to save some space inside my case.
    Components to watercool:
    3960x
    580 GTX
    ASUS RIVE
    The radiator is a Watercool HTF4 3 x 140 Dims: 495 x 152 x 65mm
    If so would it have to be push/pull?
    Thanks
  2. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    Any OC? Fans and speeds? Desirable temps?
    send from my BLADE via tapatalk
  3. David
    7 Apr 2009
    A decent 420 rad should be plenty, unless you're pushing the overclock to extremes.
  4. 3DAM
    27 Jun 2012
    I will probably be overclocking the CPU to 4.4GHz - 4.6GHz
    Fans, there will be 5 x 140MM 1200RPM Phanteks case fans and 3 or 6 (if push pull) 140mm 1200RPM Phanteks on the radiator, preferably just 3 of those due to space, although it is just about possible.
    Desirable temps, not bothered as long as they are in a safe range.
    A 420mm radiator won't fit.
    Thanks
  5. jizwizard
    jizwizard Modder
    24 Dec 2010
    3x140=420?
  6. Vetalar
    21 Jun 2011
    if You not temperature-phobic - thick 360-420 would do the job. temps would be in a safe range but higher than most LCer likes :)
    i've read some negative feedback on phanteks fans - noisy, low pressure, low CFM - maybe You consider another fans - thermalright or good old GT with adapter?
  7. 3DAM
    27 Jun 2012
    3 x 140mm is 420, of course, always has been... doh. Thanks for that.
    Phanteks are mostly aesthetic, 19db, not as bad as some.
  8. Vetalar
    21 Jun 2011
    here fans tested on phanteks CPU cooler are much louder than thermalright ty-140 on same speed... and for rads best 140 mm fan - gt with 120>140adaptor :)
  9. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    if you have a space between fan and radiator (spacer block not an actual space) you improve the flow of air through and that helps reduce the temp further.
  10. David
    7 Apr 2009
    Fan shroud(s). :thumb:
