Watercooling Converting mount holes on a radiator
Discussion in 'Hardware' started by 3DAM, 11 Sep 2012.
  1. 3DAM
    3DAM What's a Dremel?
    27 Jun 2012
    I have a 420mm radiator and 3 x 140mm fans, but the fans only have 120mm mounting holes. I'm trying to use the same fans throughout my build, so I would like to find a way of attaching the fans to the radiator, for example if I bought a fan grill with 140mm holes, could I drill additional 120mm holes. Is there an easier way, without having to drill?
    Thanks.
  2. Parge
    16 Jul 2010
    Erm how about zip ties?
  3. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    Gaffer Tape - Insta-shroud material!
  4. David
    7 Apr 2009
    If you don't want to go with the ghetto look, you can get 140mm to 120mm adapters.
    Try somewhere like aquatuning.co.uk
  5. Parge
    16 Jul 2010
    You can, but I'm not sure this will work for mounting to a rad.
  6. David
    7 Apr 2009
    Why's that, Tom?
    A 120 to 140 shroud will do the trick.
  7. 3DAM
    27 Jun 2012
    Thanks for the responses, I'd rather not go with the 'Ghetto look' :)
  8. David
    7 Apr 2009
  9. Parge
    16 Jul 2010
    Oh yeah, my bad, I wasn't thinking of a shroud, what you’ve suggested should work perfectly.
  10. notmeagain
    29 Jan 2009
    It was all my idea :)
  11. saspro
    saspro IT monkey
    23 Apr 2009
  12. David
    7 Apr 2009
    I don't follow.
    The rad is designed for three 140mm fans, but his 140mm fans have the same hole spacings as 120mm fans. Why wouldn't they fit?
  13. saspro
    saspro IT monkey
    23 Apr 2009
    Ignore me I'm being a muppet.
    I was looking at it as fitting 140mm on a 120mm spacing not the other way around
