Hi all, Just in the process of adding a few bits into my loop like temp and flow sensors. I'm having problems trying to find somewhere to put the flow sensor, the place that I think looks best is between the res and pump. Is this likely to cause a problem? Dopeyman
I'd probably stick it somewhere just after the output from the pump, but it should work ok wherever as the pump can't be outputting water any faster than it can take it in.
Ok great thanks, I keep looking at it and really can't see any where else to put it. As long as its not going to cause problems then I'm happy
