Graphics Is my GPU knackered?
Discussion in 'Tech Support' started by gilljoy, 24 Feb 2013.
  1. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Hi all,
    I've been having some issues with my machine the past few days.
    It keeps coming up and saying that the nvidia display driver has stopped working and has been recovered.
    I've done the following:
    • Downgraded to previous version of drivers - issue still happening
    • reinstalled lastet version - issue still happening
    • Installed FW update from EVGA - issue still happening
    • Cleaned out all dust - issue still happening
    • Tried upping the voltage as suggested on EVGA forums - Still Happening
    The display driver crashes when trying to do anything from opening a file, opening the start menu let alone even trying to play a game.
    Any suggestions? I don't want to start an RMA and find out the GPU isn't the issue. I've ran the usual malware scans and nothing comes up, same with memtest and HDD checks
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    yes its fubard
    ofc the final check is in another pc
  3. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Sounds like a windows conflict to me.
    If you have a spare hdd, fresh install and test on that.
  4. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Its only started happening yesterday so I'm not sure if its a windows conflict and it was working fine up until yesterday when I was playing Hitman. I installed the latest drivers on the Monday so surely if there was a conflict it would have started before Saturday?
    I've put in an old GPU Radeon x600 ( only one I had ) and the system is fine and stable and no longer freezing when opening apps like it did with the 570.
    Don't have another PC to test in unfortunately.
    I'll take an image of my SSD and do a reinstall of windows and try it out on that.
  5. JoshH
    JoshH What's a Dremel?
    19 May 2012
    Sounds broken to me :(
  6. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Time to RMA it then,
    good excuse to upgrade, time to order a 680 or 7970 and sell the replacement GTX 570 I think
  7. andrew8200m
    4 May 2009
    Working for one of the places you are likely to send it back to I will advise that you do as I have pointed out as sending it off to find there is nothing wrong with it will only annoy you.
    So fresh install on a spare hdd and test from there.
    Some windows updates can cause conflicts that lead to this sort of thing thats all :)
  8. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Will do man :)
    Going to upgrade anyway soon but may as well check before sending it off
  9. narwen
    narwen narwen
    6 Aug 2010
    I've had the same problem. It turned out to be a problem with windows.
  10. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Yeah I've just re-installed windows and it seems to be working, very strange that it just seemed to happen so suddenly though
  11. andrew8200m
    4 May 2009
    Thats windows for you.
    Microsoft make a change and do not care what they break. As far as they are concerned, its the job of Nvidia or whom ever to create work arounds in the drivers and not theirs.
  12. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Very annoying thought but at least I don't have to RMA it now :) Still thinking about upgrading though.
    Its been running on furmark for the past 20 minutes grand, any thing else I could run to test it?
  13. andrew8200m
    4 May 2009
    An intensive game is about the best sort of test you can do, heaven also works well.
  14. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    I'll download heaven now, I could also try out the new valley one too.
  15. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Yup, Heaven runs fine as does valley.
    Damn windows..
