Case Mod - In Progress ASUS Echelon- By MathMilitaryModding (FINISH)
Discussion in 'Project Logs' started by MathModding, 24 May 2014.
  1. MathModding
    MathModding What's a Dremel?
    23 May 2014
    Hi to all,
    Here you can follow the progress of the mod "Echelon" in relation to the range of accessories asus Echelon here: http://www.republic-of-gamers.fr/news-541-nouveaute-asus-kit-gaming-echelon.html
    Here is the guide who Clocks range mod the case.
    The entire casing and components will be painted in camouflage Echelon range has airbrush
    Sponsors:
    ASUS france, Veday Shop.fr, Be quiet, Western Digital, EKWB, Dremel[/SIZE]
    La config.
    Case: Corsair 600T
    Motherboard: asus Gryphon Z87
    Cpu: Intel I7 4770K
    ram: 16GO PC3-14900 Kingston HyperX
    SSD: 2 Kinston HyperX 3K 120go in RAID0
    Graphics card: SLI Asus GTX670 DCUII watercool
    Power supply: Be quiet Dark Power Pro 10 1000w
    Fans: Be quiet Pure Wings 2
    Cooling:
    Pomp: Laing DDC 1T+ 18w + top EK
    Tank: ?
    Waterblock CPU: EK LTX supremacy acetal/nikel
    Waterblock VGA: X2 EK-FC670 GTX DCII
    Radiator: 2 EK XT coolstream 240 in Pull/Push
    Fan: Be quiet Pure Wings 2​
  2. GeorgeK
    18 Sep 2010
    Moved to Modding (Planning)
    You must have pictures of work in progress for it to be posted in the Project Logs subforum
    GK
  3. MathModding
    23 May 2014
    For test the arrangement and management ;)
    [​IMG][​IMG]
  4. MathModding
    23 May 2014
    This is the 24 pins of the be quiet Dark Power Pro 1000w 10 again for the mod "Echelon".
    The afternoon to disassemble, adjust the cable length to mod to be in perfect harmony of mod.
  5. MathModding
    23 May 2014
    Here I added the latest pictures of the progress of the mod in progress
    Is this good?
  6. GeorgeK
    18 Sep 2010
    Much more like it - I'll move it back.
    I fixed all your image links as they weren't working. Either wrap the url in the tags
    Or use the insert image button above [​IMG]
  7. MathModding
    23 May 2014
    So, after a full day dedicated to airbrush stencil and paint, case 600T and finished
    Some photos for fun without much to show yet
    Stay tuned
  8. MathModding
    23 May 2014
  9. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    je l'ai dit sur facebook et je le redis maintenant: excellent boulot!
  10. MathModding
    23 May 2014
    Merci :thumb:
  11. MathModding
    23 May 2014
    MOD "Echelon in progress
    I present to you the Corsair 600T "Echelon" Edition. I still have 2 or 3 marking on the case to make.
    You can also see the placement of all internal components. The remaining tubing to do the same.
    Stay tuned
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  12. MathModding
    23 May 2014
    Start of tubing ALU is boring, I did that 2 tubes and not polishing yet, so the picture is the raw aluminium tube.
    Stay tuned
  13. MathModding
    23 May 2014
  14. MathModding
    23 May 2014
    tubing finish :)
  15. Shurika
    Shurika Minimodder
    9 Mar 2012
    Very cool! Exelent look of the build. I just can't understand one thing - those tubes are all alluminium? Or they have any protectiv cover inside them? because cooper and alluminium couldn't be in same water circle or alu would be destroyed and very fast
  16. MathModding
    23 May 2014
    yes they are aluminum. There are many ideas received for mounting aluminum / copper which is not true for waterccoling PC. there is a lot of modder who have watercooling like this without any problem after over a 1 year of use.
    you just have to be careful to use liquid anti-corrosion
    Those who speak do not test themselves :lol:
  17. MathModding
    23 May 2014
    Rad passed in camo^^
    The mod "Echelon" is finish à 95% ;-)
    [​IMG][​IMG]
  18. jimbaw
    8 May 2014
    looks so good!
    what did you use for tubing and how did you bend it? is it just nickel plated copper?
  19. MathModding
    23 May 2014
    Here is the end of the adventure with ASUS France on the theme of their range "Echelon gaming camo edition".
    A huge thank you to all my sponsors and partners who once followed.
    VedayShop.fr, Kingston Technology Europe, EK Water Blocks, Be quiet! (francophone), WD, Dremel
    I let you enjoy the pictures
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  20. MathModding
    23 May 2014
    Update in progress ;-)
