News G.Skill squeezes 2GHz out of in 49GB of memory
Discussion in 'Article Discussion' started by CardJoe, 27 Jul 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    What?
    48GB = 49,152MB
    49GB = 49 x 1024 = 50176MB
    What you said makes no sense.
  3. Guest-16
    Guest-16 Guest
    It's classed and sold as a "48GB kit" - there are 12 x 4GB DIMMs.
    But since 1GB is not 1,000MB, it's 1024MB, this actually makes a large difference when we get beyond small numbers. The 4GB DIMMs are actually 4,096MB in size - technically a 4.1GB DIMM if we round up.
    So, 12 x 4096MB = 49,152MB or 49GB.
  4. general22
    general22 What's a Dremel?
    26 Dec 2008
    I think he is referring to SI standard metric gigabytes so 49GB would be 49,000,000,000 bytes. But I thought that memory and cache generally assumes a binary gigabyte (or gebibyte or what ever stupid name). The operating system would report this as 48GB.
  5. Tasslehoff
    Tasslehoff What's a Dremel?
    25 Jan 2010
    I think they mean us to take it in the way below
    49152/1024=48
  6. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Most people think a Gigabyte is 1000 Megabytes and this is generally accepted (this is the scale that Hard drive manufacturers use) in everyday life
    A "true" Gigabyte is 1024 Megabytes, which is the standard that RAM manufactureres use
  7. Paradigm Shifter
    10 May 2006
    Don't round up, don't try to take a value that is base 2 (2^10) and turn it into base 10 (10^3)... it doesn't work. Just call it a 48GB kit, not "49GB of memory"... only hard drive manufacturers try the base 10 from base 2 trick, and it's annoying. You don't get "6.2GB" of memory from a 6GB setup...
  8. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Actually the proper method of representing is 49GB of RAM out of a 48GiB RAM kit.
  9. Meaty Pete
    Meaty Pete King of the Potato People
    8 Apr 2010
    I'M BUYING 24GB RAM KIT!!!
    (I'm not really) I just thought I'd say so as I was looking for someone to say similar yet everyone is quibbling over what is a true gigabyte. ....yawns.
  10. eek
    eek CAMRA ***.
    23 Jan 2002
    You can't mix and match a GB being 1000 or 1024 MBs! Make you're mind up and stick with it!
    It's either:
    4x1000x12 = 48000 => 48000 / 1000 = 48GB
    OR
    4x1024x12 = 49152 => 49152 / 1024 = 48GB
    NOT
    4x1024x12 = 49152 => 49152 / 1000 = 49GB!
    Thus, it's always 48GB no matter what measure you use - so long as you're consistent!
    :p
  11. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    If you work it out in bytes, which we all know are 1,024 and/or 1,000 to a KB, then it's actually 51,539,607,552 bytes, which is 51.5GB!!!!!!!!!!!1!one!!onethousandonehundredandeleven
    It's 48GB.
  12. borandi
    borandi What's a Dremel?
    27 Jan 2010
    This is the correct usage of base 2 vs. base 10. Reporters, take note, and use the correct GB or GiB when necessary. However, this article should have stated '48GiB of memory' in the title - you incite a lot of confusion as typically writing '49GB' will garner lots of negative attention. Stick to a normal factor 2 to reduce the backlash, and use the appropriate units.
  13. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    Yawn, tittie Yawn, tittie Yawn Yawn YAWN!
    Nice article though, shame about the anal posts above!
  14. NiHiLiST
    18 Aug 2001
    No it isn't, you're mixing units again, or assuming a MB as a base unit rather than a byte. 48GiB = 51.5GB.
  15. Guest-16
    Guest-16 Guest
    Thank you. :lol:
  16. wyx087
    15 Aug 2007
    wooohoo for bigger memory! it's about time! i had been at stand still with my memory size since 2007.
  17. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    pedants beware bindi will eat your brains, 48GB 49GB, who cares at that amount, its insane
  18. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    It's 49,152 Megabytes, which equals 48 Gigabytes at the correct 1,024 measurement or 49Gb at the incorrect 1,000 measurement. So stating 49Gb of memory in the title is incorrect imo.
    Anyway, epic achievement. I worry to think of the scale of the things the guys creating if he needs that much RAM!
    "I'm-a making-a super-er-computer-er!" (Italians all sound like Mario in my mind)
  19. bahgger
    bahgger Minimodder
    13 Apr 2005
    bauul, Gb =/= GB fyi
  20. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Is 49GB enough for Crysis?
Tags: Add Tags
