Case Mod - In Progress Define nano S Hot Rod Edition [FINISHED]
Discussion in 'Project Logs' started by jojoharalds, 15 Aug 2016.
  1. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Hey everyone,
    My name is jojo Haraldsson and i am a 31 year old casemodder from iceland,thank you for checking out my buildlog.
    i will be modding the Define Nano S into a hot rod themed gaming pc /mediacenter for my living room.
    The colour Theme ---
    Hot rod Red on the outside and some components will be red aswell,
    white interior
    And some chrome here and there
    also will have some black in there.
    ToDo:
    Test loop, [DONE]
    get adapters that are needed, [DONE]
    test run on the hardware, [DONE]
    Dissassemble the whole case,[DONE]
    Paint each panel of the case,[DONE]
    reassemble the case,[DONE]
    Custom Sleeve the Psu cables [DONE]
    LEAKTEST [DONE]
    Final Photoshoot
    Components:
    CASE: Fractal Define Nano S
    Fans: Fractal Design Dynamic X2 GP-12
    Aquacomputer Aquaero 6 with remote
    Mainboard: ASrock FM2A88X-ITX
    CPU : AMD 7700K @ 4.6 ghz
    RAM:8Gb Kingston HyperX Predator Beast @ 2133 mhz
    GPU: MSI - 970
    PSU:Fractal Edison M 650 Watts Gold Certified
    SSD: 120Gb Samsung EVO
    HDD: 4Tb Wester Digital Red. (Depatched)
    Watercooling:
    Pump:Aquacomputer aquastream ultimate
    Rad 1:Alphacool
    Rad 2:Alphacool
    Res: XSPC ION Reservoir
    CPU:EK Supremacy
    GPU:EK - 970 Block and an EK backplate
    Fittings :Aplhacool rigid fittings
    Enjoy the Buildlog.
    The Powersupply from Fractal
    Test fitting some hardware and planing the loop.
  2. jojoharalds
    30 Apr 2014
    Ram clearence is an issue we all know about.
    And well it is happening hhere as well,
    It is something to expect when trying to go all small on a computer build with watercooling.
    But there are ways of fixing this ☺
    [​IMG][​IMG][​IMG]
    Sent from my SM-G935F using Tapatalk
  3. jojoharalds
    30 Apr 2014
    Drain and fill port system in the making.
    Keep in mind this is only a test fit
    The final loop will be done with other piping and all the fittings will be chrome.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  4. jojoharalds
    30 Apr 2014
    I think this part of the loop will look great once it is in its finao stages
    What do you think?
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  5. jojoharalds
    30 Apr 2014
    I think this turned out alright ,
    Now on to the next part :)
  6. jojoharalds
    30 Apr 2014
    Front Panel progressing nicely :)
    Going for that Ford Model A look ,still lots of work ahead.
  7. jojoharalds
    30 Apr 2014
    and finally it continues...
    First order of parts have arrived...
    I sure love me some fittings
    together with some nickel plated tubing and Alphacool flowsensor (which in my opinion is a gorgeos Design)
  8. jojoharalds
    30 Apr 2014
    First nickel plated pipes are in place
  9. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Nice reservoir :)
    Did you plan some pinstriping ?
  10. jojoharalds
    30 Apr 2014
    thanks , no pinstriping is not planned for this build.
    But who knows.
  11. jojoharalds
    30 Apr 2014
    we i am able to close everytging in the back.
    and the front end (Grill) is in progress aswell.
  12. jojoharalds
    30 Apr 2014
    Preparing the Case for paint [​IMG][​IMG][​IMG]
  13. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    what tool did you use to cut the panels?
  14. jojoharalds
    30 Apr 2014
    Jigsaw
  15. jojoharalds
    30 Apr 2014
    Got an extra set of fans today.
    and started painting them.
  16. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    Only thumbs up from me :thumb: :thumb: :thumb: :dremel: :clap:
    I like it :) Different theme and colours from what we are used to see. Especially like the way you mounted the XSPC res half outside the case :D
  17. jojoharalds
    30 Apr 2014
    Thank you very much glad you like it ,(and yes i am trying to different things i haven´t seen already. )
  18. jojoharalds
    30 Apr 2014
    Finaly i can start painting.
    First i had to make my paint booth Bulletproof.
    the i got cought (and had to take a mugshot)
    but i am still on track .... unstoppable
  19. jojoharalds
    30 Apr 2014
    everything was sanded and primer applied after applying primer i wet sanded everyrhing and cleaned it up.
    Now it was time to add the colour.[​IMG][​IMG][​IMG][​IMG][​IMG]
  20. jojoharalds
    30 Apr 2014
    A few Spraycans and 30 Rivets later :)
    I think the result is looking alright :)
    -- Define Nano S Hot Rod Red --
