Watercooling Best Quad Radiator (480)
Discussion in 'Hardware' started by bdigital, 27 Apr 2012.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hey all, im going to treat my sig rig TJ07 to a radiator.
    Whats the best quad rad around? Ive read this roundup but I didnt really think the conclusion was.........conclusive! http://forums.bit-tech.net/showthread.php?t=211910
    My current favs are the phoyba g changer, the ek coolstream or the xspc.
    Whats good?
  2. David
    7 Apr 2009
    Is a quad 140mm too big for the TJ07, or maybe a triple 140mm (as it's likely to have as much, if not more surface area than a quad 120).
    JBond and PingPong like this.
  3. bdigital
    10 Aug 2010
    Not in the base, not without modding anyway. The 120 squeezes in height wise, but I have more space length ways.
    Phoyba g changer, xspc or ek coolstream?!
  4. Big Elf
    23 Apr 2009
    Alphacool UT60 for low to medium speed fans. I like this one.
    Forgot the review Mainly copper, screw protectors on the tubes and a very good price.
  5. bdigital
    10 Aug 2010
    Is it a very good performer steve?
    Sent from my GT-I9100 using Tapatalk
  6. Big Elf
    23 Apr 2009
    According to the temp comparisons at here it's the top performer at most fan speeds. If I was replacing my RX480's I'd get them.
  7. bdigital
    10 Aug 2010
    Thats a good suggestion thanks for that. Any others worth considering.
  8. bdigital
    10 Aug 2010
  9. Big Elf
    23 Apr 2009
    Me again:D They're all going to perform well and to a similar level with low speed fans (I seem to recall you prefer low speed fans). The SR1 is slightly thinner at 54mm and would previously have been my first choice (I like the inbuilt shroud) but price wise the UT60 edges it for me especially with the copper construction.
  10. bdigital
    10 Aug 2010
    Thanks big elf, your right I prefer low rpm fans. Well ut60 looks a lovely bit of kit so I'm sure I won't be dissapointed.
    Probably ordering within the next 2 weeks.
  11. echo three
    echo three What's a Dremel?
    26 Jan 2012
    When you say low speed fans what sort of speeds are we talking?
  12. bdigital
    10 Aug 2010
    well I suppose the requirement is actually driven by noise. I don't care what the rpm is as long as it is quiet and still performs well. I'm thinking between 800rpm and 1000rpm
  13. cpachris
    cpachris What's a Dremel?
    11 May 2012
