News Nvidia denies GeForce GTX 970 design flaw claims
Discussion in 'Article Discussion' started by Gareth Halfacree, 26 Jan 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The problem with 'user experience' reports is that every possible performance issue is attributed to 'bad vRAM', rather than to turning up every setting possible.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    And the problem with using FPS to measure RAM speed and usage is that the lack of either of those has very little effect on FPS. As edzieba alludes to most of these 'user experience' reports have come from tests based on bad configurations.
  4. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    I saw this on Guru3D and one of the guys has written an app to test this outside of games, so FPS isn't something that comes into it.
  5. Corky42
    30 Oct 2012
    And that program is meant to be run in headless mode, how many of the posted screenshots of said 'benchmark' program were run like that ?
    And how do we know this 'benchmark' program is handling things correctly ? From a (translated) forum post the author made discussing his own program he says...
    That sounds like he said that his program isn't handling the segmented memory correctly.
  6. ZeDestructor
    ZeDestructor Minimodder
    24 Feb 2010
    Well looks like I've found the one corner of the internet that isn't me and like 2 other actual computing people masturbating over computer architectures that also have rational minds! bit-tech/CPC readers deliver yet again!
    osnap!
    Personally I've actually hit the point of complete VRAM overload requiring the uses of system RAM, and my FPS drops from 60fps to around 10fps as a result (again, nubs thinking some stutter at 45fps = RAM partitioning-related... what nubs), so a 3% difference between 970 and 980 slowdown is to me attributable to other stuff, not the partitioning of VRAM.
    For now I'm still recommending the 970, and waiting for actual technical info from somewhere reputable and skilled like AnandTech or Timothy Lottes (former Nvidia engineer, inventor of FXAA - the entire idea of post-render AA while at it. He's at Epic (Unreal Engine) now, as I recall) blog or RealWorldTech.
  7. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Well that thread over on Guru3D is over 900 posts now and lost the plot hundreds of posts ago and has since turned in to a mud slinging fight, 'I'm right, you're wrong!'... 'No, I'm right and you're wrong!'... blah.
    Did nVidia do anything 'wrong' with the architecture of the 970? I don't think so. Isn't it also likely that anyone in a system situation where this may genuinely affect them, went with the 980 anyway?
    Either way, if I had £300 for a GPU right now I would still go for a 970 and I am certain I would still be happy with the performance that I would get. I think many have lost sight of that...
  8. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    I'm still 100% happy with my GTX in ANY game at 1080 or DSR (4k res) stuff....
    What game uses more than 3.5Gb of VRAM??
  9. Harlequin
    Harlequin Modder
    4 Jun 2004
    nv should have said the card was a 3.5GB card and be done with it - now they are again trying a `bumpgate` and brushing it aside.
    quite a few non English websites are showing issues when pushed at 4k and over 3.5gb ram
  10. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    I am running a evga 970 oc @ 144hz on an Asus swift pg278q monitor with games COD:AW and Far cry 4, with nothing but silky smooth eye candy...i have never gamed so richly.
    No probs for me as yet.
    N17 dizzi likes this.
  11. GoodBytes
    20 Jan 2007
    Wasn't that claim from Nvidia forum mod? (ie: not official) And didn't they say that they are investigating?
  12. Harlequin
    Harlequin Modder
    4 Jun 2004
    no the nv rep said it was a crossbar issue that really wasn't an issue - and the green team fangirls are believing them - a bit like bumpgate
  13. Shirty
    18 Apr 1982
    For 98% of users does any of this even matter? For non-users who aren't actively planning a 970 purchase this simply cannot matter.
    Enjoy your gaming, and if your card is broken then RMA it.
  14. Harlequin
    Harlequin Modder
    4 Jun 2004
    heres a question - has anyone actually tested the R290X under the same display conditions to see its performance drop?
    COD:AW @4K with FSAA and without FSAA for example?
  15. Nexxo
    23 Oct 2001
    No, but I have an ATi Radeon 1650XT if you want me to have a go.
    No?
    The_Crapman likes this.
  16. Corky42
    30 Oct 2012
    Putting your obvious bait at trying to start a GPU war aside, no one is taking what Nvidia have said as gospel.
    People just want someone like yourself to provide evidence to backup their claims other than using a program in a way it wasn't intended to be used, or some random YouTube videos purporting to show micro stutters.
    Unless you have bought a 970 to do CUDA work then from what i can tell no, DirectX and OpenGL has automatic memory management.
  17. Harlequin
    Harlequin Modder
    4 Jun 2004
    `random` - its from a Russian tech website ......
  18. Harlequin
    Harlequin Modder
    4 Jun 2004
  19. Harlequin
    Harlequin Modder
    4 Jun 2004
    IF it had a properly working SMM , then it be matching a 980
    as it is , at 4k a 290x is up there with a 980 and ahead of a 970 (ram addressing aside)
  20. loftie
    loftie Multimodder
    14 Feb 2009
    IMO if you consider it false advertising I wouldn't find it amusing, I'd find it worrying. If the final 500mb is that poor performing they should have just disabled it and left it at 3.5gb.
