Other Screws for a Corsair H55
Discussion in 'Hardware' started by REDDEVIL-UK1, 11 Jul 2013.
  1. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    Does anyone know where i can acquire the screws (long & black) for the Corsair H55 at all as i'm looking to put another fan on it.
    Thanks in advance :thumb:
  2. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Possibly from the Corsair web store, or contact Corsair and ask them as they may send you some for free.
  3. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    Theres always hardware stores. Mine stocks practically every diameter of mechanical screws up to 2.5in long. Except you probably won't find them with the same head or spray painted black.
    If you makes you feel any better. Dual fans has a marginal increase in performance. At best you are looking at 2 degrees if the radiator is thick (which isn't). Otherwise you are going to be getting less than that.
    What you are looking for is high RPM on the fan if you really want cooling performance. Perhaps a quieter fan so you can pump the RPM some more. You might end up with something better than quieter.
  4. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    take one of your existing srcews with you to a hardware or diy store and ask them to find you some.
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    You need UNC 6 - 32 x 1.25" (31.75mm) screws.
  6. Shirty
    18 Apr 1982
    This indeed.
    I noticed a princely improvement of 1 degree difference when I added a second SP120 to my H55, at the expense of double the noise.
    I sold the second SP120 ;)
    YEHBABY likes this.
  7. Big Elf
    23 Apr 2009
