News Asus teases GeForce GTX 970 DirectCu Mini
Discussion in 'Article Discussion' started by Gareth Halfacree, 1 Dec 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. David
    7 Apr 2009
    You'd think a card designed with small, cramped, builds in mind would be designed to exhaust hot air out via the PCI bracket. No?
  3. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    A possible reason cold be that the vent slots don't allow enough air to effectively escape quick enough.
    As the 9xx series cards are so efficient and much cooler I wonder if they will be able to bring out a 980 mini card? Personally I would like to get either this or a 980 mini and then slap on a full cover water block for the extra cooling needed to unlock maximum over clocking potential.
  4. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Blower type coolers don't work on short cards because there isn't enough room for the cooling fins. Well, at least there isn't enough room to cool a 150W+ card. You can see this on the reference 970s using the short PCB, they use the same type of blower as the 670 where the fan extends well past the PCB.
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Want it, want it now.
    More importantly, when/where/how can we get a full cover block for it?
  6. Combatus
    16 Feb 2009
    My thinking exactly!
  7. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    My short Zotac GTX970 is doing just fine in my ITX box...
  8. Combatus
    16 Feb 2009
    Yeah that's a pretty short PCB too. I'm looking at this or the Zotac for my new build I think.
  9. Nexxo
    23 Oct 2001
  10. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    gigabyte already released an ITX size card...
  11. littlepuppi
    26 Apr 2009
  12. Combatus
    16 Feb 2009
    Yeah I was looking at those the other day. The short PCB Zotac is already supported too so fingers crossed!
  13. littlepuppi
    26 Apr 2009
    im running the zotac in my sg05 and its great.... bit more heatsink space as well :)
  14. David
    7 Apr 2009
    So, beaten to market by both Gigabyte and Zotac. :lol:
  15. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Too bad it's not a... Strip tease :cooldude:
  16. SchizoFrog
    5 May 2009
    I've been reading bad things about the Gigabyte version, apparently it is extremely loud, even for a mini card. Obviously not an issue if you are going the water route as I mentioned above.
  17. Redbeaver
    15 Feb 2006
    Zotac is quiet but ive heard it can be spotty as well. Although mine is perfectly fine. So who knows...
