Case Mod - In Progress Project C.Through [Buildlog] "Make it Yours" - Completed
Discussion in 'Project Logs' started by jojoharalds, 30 Oct 2015.
  1. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Project C. Trough
    Hey everyone ,and welcome to another project of mine,
    First off i would like to thank Coolermaster for making this Possible,
    Also would like to thank Icemodz.com for always beeing there for me with there awsome
    Sleeved cables and Led´s
    Thank you to Gigabyt for making this possible
    In this build i will be building in the Coolermaster Master Case 5 with some minor changes to the structual design (since the guys over @ coolermaster together with some of the best modders out there already did a heck of good job on designing this beast of a case :) )
    Watercooling components will be from Bitspower ,Ek waterblocks,Primochill and some more,
    For other components like motherboard Gpu and ram we will see if buy some new stuff along the way or just use what i have
    Now @ last i want to Thank you for checking out my Buildlog,
    Hope you enjoy it,
    Lets get this started with the Unboxing of the Coolermaster Case,
  2. jojoharalds
    30 Apr 2014
    well the fun has started....
    ripped off the frontpanel ....
    starting to work from there.
    [​IMG][​IMG]
    Sent from my SM-G920F using Tapatalk
  3. jojoharalds
    30 Apr 2014
    since it is late at night right now and all the stores are closed i thought well lets try the extra top panel conversion a got aswell
    I think it looks great .....but why not make it possible to install a 360 radiator the same way in the top.(since this bracket is clearly thought for aio waterxooling units.)
    But i will work my way around that i guess [​IMG]
  4. jojoharalds
    30 Apr 2014
    Stripped out the drive Cages and that was the most easy swap you will ever experience in any computercase :)
    Everything is easy detacheble and no problem to attach later if needed with one or two thumbscrews .
    I however was a little dissapointed that they have decided to strict the use of Radiator Thickness and "placement". :(
    you will not be able to fit all 360 rads in the front and most likely won´t be able to fit a 360 rad on top,but they made a really nice bracket for AIO or 240mm radiators (thumbs up for that)
    Well i just will have to find a way aroiund that :D
    Keep u Posted!
  5. jojoharalds
    30 Apr 2014
    Hey everyone got some stuff in right before the weekend,
    1x 240 EK PE radiator
    2x 120 EK PE radiators
    1x mini res from Bitspower (With air valve)
    and some new Ghost fittings from Primochill
    next i will have to buy some paint stuff and materials,
    keep u posted.
  6. jojoharalds
    30 Apr 2014
    Getting Things reddy for paint.
  7. jojoharalds
    30 Apr 2014
    Started on paint preperations and painting.....
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  8. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    I ordered the same case, and was gonna go with orange theme, but now i can kiss it goodbye ;)
    I'll be watching.
  9. jojoharalds
    30 Apr 2014
    WEll blue was taken red was taken white is boring,
    pink done that already,so well going on a different route with the orange (and a taste of UV)
    But good luck with you´res.maybe i will take a look once you start :)
  10. Cheapskate
    13 May 2007
    There's always tangerine. ;)
  11. jojoharalds
    30 Apr 2014
    hehe yes there is
  12. jojoharalds
    30 Apr 2014
    Here a little overview of the paintjob.
    next a little paintjob on the backpanel.
    Keep u Posted
  13. jojoharalds
    30 Apr 2014
    They said "Make it Yours"
    I guess i did :)
  14. jojoharalds
    30 Apr 2014
    Hey everyone,
    I am proud and Thankfull to announce my new sponsors for this Project,
    GIGABYTE,
    They where so very kind and sponsored me with this badass Motherboard,
    THANK YOU GIGABYTE.
  15. jojoharalds
    30 Apr 2014
    Starting on getting hardware into the case and planing from there,
    since i want everything to fit nice and clean,withoug getting a too crouded overall look,
    First thing is the Powersupply,which too comes from coolermaster
    and is the V1000 which should be more than enough for this Build :)
    Here are a few Pictures to show you how easy it is to install a PSU in the Master Case 5 Pro.
  16. jojoharalds
    30 Apr 2014
    Painting the Top of my corsair dominator dimms ,to match the colourtheme.[​IMG]
  17. jojoharalds
    30 Apr 2014
    After letting the primer dry over night i sanded it a little bit and gave it some paint .[​IMG]
  18. jojoharalds
    30 Apr 2014
    Well the dominator ram is all back together .
    cleaned the Gpu blocks while i was at it.
    and installed the 4790k into his new Home.
    The Gigabyte z97x SOC will suit him well and maybe even get him a nice sable Overclock ☺[​IMG][​IMG][​IMG]
  19. jojoharalds
    30 Apr 2014
    And the fun keeps on goin.....
    cleaning the cpu block from bitspower .
    installimg the cpu block onto the motherboard.
    putting some colour on the gpu.
    and got the liquid for this project.
  20. jojoharalds
    30 Apr 2014
    Some christmas modding
    Merry Christmas to all of you.
    [​IMG][​IMG][​IMG]
