Case Mod - In Progress Mac pro 2016 (updated 24/10)
Discussion in 'Project Logs' started by b2bk, 10 Feb 2016.
  1. b2bk
    b2bk What's a Dremel?
    11 Jun 2014
    I am not a fan of Hackintosh but i love the Mac pro design very much. I had a Mac pro barebone last year but i was so busy to do not anything with it. Now i have a freetime to mod it. This is the first project in 2016 and i hope you like it.
    My hardwares are not ready and i just want to mod Mac pro while they come.
    Review my barebone
    The first pic. The barebone without 2 hdd tray. Make sure to need hdd tray with new style
    Disassemble Mac pro
    Remake the I/O
  2. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Always up for a MacPro mod. subbed.
    J.
  3. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    +1 oh yeah ! :clap:
  4. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    great start.
  5. General_Confusion
    General_Confusion Now Where was I?
    3 Jul 2010
    I have one of these systems myself so I'll be interested to see what you do with it :naughty:
  6. b2bk
    11 Jun 2014
    Thank guys and to be continue
    Finishing The I/O with original fan mount
    Making mainboard mount
    The front base with 2 mastic layer
  7. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    I'm liking what I'm seeing so far!
    -Jeffinslaw
  8. b2bk
    11 Jun 2014
    Thanks
  9. b2bk
    11 Jun 2014
    Updated 28/2
    I used pvc material to make the grid of front base but i didn't succeed so i must use aluminium to fix it and it took me 2 week.
    to make the grid with aluminium plate
  10. thegyufi
    21 Mar 2011
    When I did my G5 case, I used some epoxy to do the same sort of work. Maybe it will help you :D
  11. b2bk
    11 Jun 2014
    Thank you, Actually i watched your project and like it very much. I try to find good epoxy but i can not in Viet Nam
  12. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Glad to see again a nice job with G5 Dude…
    as a G5 lover ı know the problems at the case…
    İt is very hard to keep the holes respectively.
    To set the top row, you must slide 1hole to right or left…
    But ıt is not enough… you must slide 1/2 hole upwards….and that is ımpossible.You have the same problems at the buttom edges.
    That was the reason why ı made a new backlate…
    You have the opportumity to hide them with dark painting , but I did not have this chance…
  13. b2bk
    11 Jun 2014
    Thanks to show me the problem but i knew it and i made a mistake when i made the hole without calculating space.
    It is difficult to make the grid and i don't want to do it again because i mad the grid 3 times and it took me 2 weeks. I accept the grid with the fault
    I hope you understand and like my project.
  14. b2bk
    11 Jun 2014
    Making partition panel for psu and hdd
  15. Jipa
    5 Feb 2004
    The G5 case is definitely my favorite of all the things Apple has ever made. Just classy :)
  16. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Good luck with your nice worklog Dude.
  17. b2bk
    11 Jun 2014
    Updated 6/3
    Making the psu mount
    Hdd tray in process with PPE plate
  18. b2bk
    11 Jun 2014
    Updated 30/03/2016
    finish hdd tray and making radiator mouting and psu cover
    i bought Zalman reserator 3 max dual with dead pump from my friend and i tried to modify the block and radiator with hardtube fiting like a custom watercooling. Now i have a new block adapter with hardtube fiitngs. It's unfortunately i found a crack on the block cpu but i have not tested . I will finish and test my watercooling system.
  19. b2bk
    11 Jun 2014
    Making the mount plate for pump and somthing else
    An cheap vga block from my friend but it was unavailable for my evga gtx 750. Saving the money i got a chipset block for my evga gtx 750
    Some pics with psu cover and side windows
    I got some drinking straws for tube path example
    And the result of the tube path . I am not sure the Alphacool mini pump is available for this tube path . Do you give good counsel to me ?
  20. b2bk
    11 Jun 2014
    New vga block
    Making some covers
