Other Which Antivirus do you use and why?
Discussion in 'Software' started by short1uk, 20 Sep 2011.
  1. short1uk
    short1uk Minimodder
    20 Sep 2011
    Hi guys, new to the forum so be gentle on me ;)
    I am an IT Engineer and reinstall machines for a living. People ask me to put a free AV on their machines so I always put Microsoft Security Essentials on. I use this myself along with Malwarebytes and have had no problems, yes it's slow to scan but its free so I can live with that.
    Other day I met this chap and he said its rubbish, he recommends ESET. So out of all the free ones and paid ones which would you sell or install for free on a customers machine?
    Cheers
    Catherine
  2. jossi007
    jossi007 What's a Dremel?
    26 Sep 2011
    I'm an IT engineer myself, and found out with experience that every technician likes an other anti virus.
    Bottom line, I have seen viruses bypassing every existing anti virus. Security Essentials is actually very accurate and in my experience will find many more viruses than the popular AVG free version, especially the resident shield is very strong.
    Right now at the moment I would definitely recommend Microsoft Security Essentials.
  3. windy
    windy What's a Dremel?
    21 Sep 2011
    I'm a fellow newbie on here so I'll go gentle ;)
    I've used AVG on a number of systems for a number of years and always found it very good at stopping the nasties, and also easy to use. Definitely prefer it over Security Essentials. I always combine it with Malwarebytes too.
    I must admit I've never used ESET so can't comment on it.
    windy
  4. samkiller42
    25 Apr 2006
    The general consensus for forum members is that MSE is one of the best Anti Virus available (inc Free and Pay)
    I use MSE on all my machines, and all other machines i come into contact with, No horror stories yet.
    Sam
  5. murraynt
    murraynt Modder
    6 Jun 2009
  6. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Microsoft Security Essentials here. Never had any problem. Found viruses on a PC where Symantec didn't.
  7. longweight
    7 May 2011
    MSE for me, never notice it doing anything really but it seems to work!
  8. Monty
    Monty What's a Dremel?
    19 Mar 2011
    Mse nails all the viruses my varsity colleagues have thrown at me.
    Best of all it has no irritating startup popups, autoupdates with windows update and is free!
  9. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Avira still - though hopefully they won't mess it up with v10 SP2 - I can live with the popup which is only on the boot update, every other update check is a small square box at the bottom right hand corner of the screen, which I'm pretty sure you can minimise if you wish.
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    well if you are installing free versions on customers machine, then it has to be MSE, licensing of most of the others don't allow for business users to install free ones, either on own machine or customers.
    btw, AVG allow you to install OEM licenses on computer repairs, so you could upsell a better paid for version.
  11. Xcellente
    Xcellente What's a Dremel?
    27 Sep 2011
    any free one will do
  12. Unicorn
    25 Jul 2006
    Avast! Professional edition on my workstations and MSE on my laptops. Always had great results with Avast! and horrible trouble with Norton, ESET and McAfee so avoid them. I usually recommend Avast! free edition to private customers.
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I used to use AVG but they it just stopped working and I couldn't reinstall so I switched to Avast
  14. brave758
    brave758 Minimodder
    16 Apr 2009
    MSE all the way lite and very little user interaction required. I love it
  15. rv88uk
    rv88uk What's a Dremel?
    28 May 2011
    Another one for MSE here, I've never had a problem with viruses and it just sits quietly in the notification bar, no 'license running out' or 'are you sure you want to do this?' pop ups. Whenever I'm asked about AV it's the one I recommend (v. user friendly).
  16. adamix
    adamix What's a Dremel?
    21 Sep 2011
    AVAST! is quite reliable, MSE and AVG are not too bad either. All these are better than the dreaded pay-for McAfee that can be worse than the virus it tries to protect you from.
  17. adidan
    25 Mar 2009
    Avira AntiVir but if it's for customers then it'd be MSE.
    I put that on my mums laptop, I think the free pop up would freak her out (although I do recall seeing someway of disabling that somewhere). The only time she had problems was because she was clicking links she shouldn't.
    IT helpdesk days came in handy with that one, luckily I'd put Malwarebytes on it which is easy to talk through.
    So yup, for customers MSE and Malwarebytes.
    Teelzebub likes this.
  18. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I use Avira because it's good and it's free.
  19. Juu
    Juu Haters Gonna Hate [✓]
    13 Jul 2008
    Also work in IT..
    Microsoft Security Essentials is what I use/recommend, however most customers/people I deal with use paid for AV, such as symantec or mcafee.
    Aslong as you have common sense your anti virus is not really needed.
  20. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Sophos, because it's been free from school/work/university and always seems unobtrusive and effective. My laptop has Security Essentials on it though.
