Other GTX 670 drivers
Discussion in 'Software' started by ceryni, 20 Aug 2014.
  1. ceryni
    ceryni Idiot
    6 Jul 2011
    Hi everyone,
    I've heard there are problems with this and that drivers? I used to just DL whatever I felt like..
    Can anyone tell me the drivers I should use for gaming and fullscreen HD with the GTX 670?
    Thanks
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I just use the latest ones from NVidia, never had any issues as far as I can remember. If your running Vista/7/8/8.1 64bit, these are the ones you need.
    ceryni likes this.
  3. ceryni
    ceryni Idiot
    6 Jul 2011
    Perfect thank you. Yes it's 8.1 64bit. I hated Win8 at first but grown to enjoy it. Never use the start menu though. ever.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I've never had any problem with any driver release so far with my gtx670 and Windows 8.1. Even with beta driver which is what I seem to have most of the time I can't ever recall seeing a driver reset happen. Perhaps some driver release has some issue in a particular game, but I may not have noticed or not been playing a particular title at the time I had X driver version so I can't say.
  5. theshadow2001
    3 May 2012
    I've sli 670s on the beta driver releases. No problems under win 8
  6. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Whatever is the lastest WHQL release from Nvidia is the safest bet. As others have said I have run the most up to date betas on my systems for as long as I can remember without issues.
