Hardware NZXT Launches New Manta Mini-ITX Case
Discussion in 'Article Discussion' started by Combatus, 26 Jan 2016.
  1. Combatus
    16 Feb 2009
  2. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    46L volume and classed as mini-itx, I hope some modders change that :D
  3. Combatus
    16 Feb 2009
    Yeah it is a beast. I was kinda hoping for a radical design given NZXT's out-of-the-box thinking with some of its other cases. It's different externally for sure, but the innards aren't anything spectacularly different.
  4. Parge
    16 Jul 2010
    46L volume for an ITX case. What an absolute joke when you can fit a full loop in a 15L NCase M1.
  5. Taua
    Taua What's a Dremel?
    20 Sep 2014
    Looks nice, but my hadron air cost only a tad over £100 and that included a 500w gold PSU. I always thought the point of ITX was to be really small, cases that verge into MATX size raise build questions. For this cases size, it still has a tight GPU area and wastes masses of space on the drive area. Like the curves though.
  6. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    looks a bit like the turrets from portal
  7. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Looking forward to seeing what modders come up with...
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Yeah, although I'm sure this will appeal to someone, it isn't remotely what I want from an mITX case. 46l is absolutely massive, and it doesn't even look particularly spacious inside somehow! I want my mITX cases to be small, and given the number of really good mITX enclosures out there that are less than half the volume of this beast, I'll be staying well clear of this case.
  9. Impatience
    Impatience Minimodder
    6 Apr 2014
    It looks gorgeous, but practicality? Out of the window! I know some people want to be able to do watercooling in an ITX case, but do you really need the two 280mm rad fittings in every single one of these ITX cases that comes out?
  10. suenstar
    suenstar Collector of Things
    13 Sep 2009
    I like the style of the case but the size isn't justifiable for an ITX for me.
    Shame as I'm looking at replacing my current case for a new one in the next couple of months, but I want something quite a bit smaller than my tower.
Tags: Add Tags
