Windows Blue screen of death!!!
Discussion in 'Tech Support' started by mr.a2008, 14 Oct 2011.
  1. mr.a2008
    mr.a2008 What's a Dremel?
    3 Aug 2009
    Hey guys,
    I just received the blue screen (of death) and I think it was a hardware failure but I dont have a clue what piece it was and was wondering if the event manager would have that info and which part would help me identify the faulty component?!
    Here's the result of event manager:
    - System
    - Provider
    [ Name] Microsoft-Windows-Kernel-Power
    [ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
    EventID 41
    Version 2
    Level 1
    Task 63
    Opcode 0
    Keywords 0x8000000000000002
    - TimeCreated
    [ SystemTime] 2011-10-13T21:13:50.483635100Z
    EventRecordID 41389
    Correlation
    - Execution
    [ ProcessID] 4
    [ ThreadID] 8
    Channel System
    Computer 64bit-PC
    - Security
    [ UserID] S-1-5-18
    - EventData
    BugcheckCode 209
    BugcheckParameter1 0xfffffa8004b7d66d
    BugcheckParameter2 0x2
    BugcheckParameter3 0x0
    BugcheckParameter4 0xfffff8800163cfa3
    SleepInProgress false
    PowerButtonTimestamp 0
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  3. mr.a2008
    3 Aug 2009
    This is what it gave me. so what do you think?
    DRIVER_IRQL_NOT_LESS_OR_EQUAL
    STOP: 0x000000d1 (0xfffffa8004b7d66d, 0x0000000000000002, 0x0000000000000000,
    0xfffff8800163cfa3)
    *** - Address 0x0000000000000000 base at 0x0000000000000000 DateStamp
    0x00000000
  4. Houndofhell
    Houndofhell One Particle to Rule Them All
    9 Jul 2009
    Alrightly well given its a Windows-Kernel-Power error and the DRIVER_IRQL_NOT_LESS_OR_EQUAL error, this sounds mightily like its a memory issue.
    If you have any Overclocks get rid of them, then run memtest86+ let it run through a full test.
    Hopefully it should be able to tell you if theres an issue with memory.
  5. Kernel
    Kernel Likes cheese
    29 Sep 2003
    or
    Source: http://www.eventid.net/display.asp?eventid=41
  6. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Any drivers you recently changed? Also if you check your minidump files you might be able to spot the problem cause however BlueScreenView will do the job for you much more easily.
  7. laincognita
    laincognita What's a Dremel?
    12 Oct 2011
    How do you open your minidump files please? I can never manage it :(
  8. MrWillyWonka
    25 Jul 2004
    C:\Windows\Minidump and you will have to copy the files to the desktop and use notepad to open them (you can't open direct from the minidump folder due to system restrictions). However a lot of it is mumblejumble. BlueScreenView will help you view these files with ease.
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    good advice in here.. I can add
    prime on blend.. memtest.. adjust to reach your goal temps loaded and it should pass these tests
    Crossing likes this.
  10. Crossing
    Crossing What's a Dremel?
    20 Jun 2011
    +1 for memtest, same thing happened to me and memtest detected it
  11. mr.a2008
    3 Aug 2009
    Nothing came up in my memtest results but the machine is still functioning! Must of been dodgy connection which is fixed! Still thanks guys
  12. enterobsidian
    enterobsidian Hopless World Wonderer
    11 Apr 2011
    mr.a2008 - You weren't upgrading your antivirius by any chance?
    enterobsidian
