Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    - Sponsors -
    [​IMG][​IMG][​IMG][​IMG]
    [​IMG] [​IMG]
    Aquatuning España / Atlas Informática / NZXT
    ProSilentPC / Seasonic / IzarMicro
    Gracias a todos los sponsors por colaborar en el proyecto.
    Many thanks to all the sponsors for the support given to this project
    "Little Angel" Hardware List
    -[ Water Cooling Parts ]-
    Pumps: 2 x MCP655 (WAITING)
    Rads: ¿? (WAITING)
    Reservoir: ¿? (WAITING)
    Fans: 13 x 120mm NZXT (NZXTFX120LB) and 2 x 140mm NZXT (NZXTFX140LB) (ORDERED)
    Fittings: Bitspower, Matt Black in 19/13 (waiting for more...)
    Diagnostic:
    Aquaero 5 XT (WAITING)
    Extras: Aquaero 5 XT Accesories (OK)
    Tubo: Primochill Primoflex – White 19/13 (OK)
    Killcoil: 3 x Pulsar Modding (OK)
    -[ Other ]-
    Wiring: 18 AWG for custom PSU length wires and 24 AWG for fans (OK)
    Connectors and pins: To use with Aquaero, Mother Board, sound card...(OK)
    MDPC-X: Washers, nuts, sleeving, heatshrink etc.. (WAITING)
    This is a Big system update that I was waiting for the last couple of years. I will change from a e8500 to a i7 2600k or 2700k if it’s really worth it!
    Maybe If the build takes longer Ivy Bridge… but don’t think they will release them anytime “soon”
    Hope you guys like it, will keep the log updated.
    Now I have to wait for some parts and wait some time to order some others…
    Tribble likes this.
  2. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Worklog Index
    October 2011
    * 04/10/2011 - Little Devil at home!
    * 09/10/2011 - First Bitspower fittings arrival
    * 11/11/2011 - Powered By Seasonic!
    * 12/10/2011 - NZXT Fans from Atlas Informática
    * 12/10/2011 - Modifying NZXT 120mm fans
    * 13/10/2011 - Modifying NZXT 140mm fans
    * 18/10/2011 - Seasonic's X-850 @ Home!
    * 19/10/2011 - Photoshooting Seasonic X-850
    * 20/10/2011 - Changing bitspower O-rings
    * 31/10/2011 - "Custom" thumbscrews!
    November 2011
    * 22/11/2011 - Lian Li metal casters for Little Devil
    December 2011
    * 22/12/2011 - Seasonic x850 x 2!!! PSU
    January 2012
    * 09/01/2012 - Little Devil's Dual PSU support
    * 10/01/2012 - Dual PSU "starter" PCB and Led PCB
    * 12/01/2012 - Lian Li Metal casters installed!
    * 15/01/2012 - Swiftech Limited Edition #124 Block
    * 16/01/2012 - Swiftech "Custom" Limited Edition!
    * 20/01/2012 - Cardboard Rads! (test fitting!)
    * 24/01/2012 - Wires everywhere
    February 2012
    * 01/02/2012 - Some sleeving color pattern testing
    * 01/02/2012 - Even more color pattern testing...
    * 05/02/2012 - Fan sleeving testing
    * 18/02/2012 - Seasonic x850 Power Plug mod
    * 25/02/2012 - AQUATUNING's 15 Kg of awesome stuff!
    * 28/02/2012 - Radiators test fits + FAN sleeving!
    March 2012
    * 01/03/2012 - NEW sponsor! (Izar Micro) - and more sleeving work on radiators
    * 13/03/2012 - Power Adjust 2 sleeving + rack setup
    * 14/03/2012 - Power Adjust 2 sleeving + rack setup (part 2)
    * 15/03/2012 - PROSILENTPC goodies arrival
    * 18/03/2012 - Drilling the Little Devil for better wire management...
    * 21/03/2012 - AQUAERO 5 XT @ Home! (waterblock setup and front plate change)
    to be continued...
  3. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
  4. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Ok so here you have some pictures of the "unboxing" (it was a fast one...)
    My Lian Li looks like a joke next to the Little Devil...
    My precious....
    The case in It's final location
    There is a lot of work to do... can't wait to get started :)
  5. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Just placed an order yesterday for some Bitspower fittings but I will have to wait some time since there are some fittings out of stock...
    The fans that I will use for this build are already shipped!
    Thanks to Atlas informática and NZXT
    13 x NZXT FX120LB
    2 x NZXT FX140LB
    Will need to order 3 x Power Adjust 2 to be able to control them with Aquaero 5 XT.
    I think Aquaero 5 XT supports up to 1.5 A per channel and the radiator fans use about 0.35 A at full speed that makes 1.4 A but still wanted to have some headroom...
    I've also updated the first post with all the hardware I will use (still thinking of which PSU :))
  6. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    looks like this is gonna be good :clap:
  7. peteski
    peteski long live the pc
    8 Jun 2011
    chelmsford,uk
    thats one bad ass case you got there. and i googled the mobo and that is sweet as i thought my extreme 4 looked good . cant wait for more updates
    subscribed :rock: :rock:
  8. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hope so!
    Thanks for the support :clap:
    You are the 1st to subscribe afaik!
    And yes, the board looks sexy (wait... sexy? I think I spend too much time in here!)
  9. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    So a little update (pictures really...)
    I've spend the day checking online stores and filling shopping carts :D
    The part that I enjoy the most is when you have to plan all the fittings you thinkg you are going to need... you need to study to learn all the fittings available!
    I just ordered some more Bitspower fittings, but just checked what I have in stock at home... and here are the picutres
    Compression Fitting 19/13 - Matt Black
    45º Adaptaer + Compression Fitting
    "Quick Disconnect" from Bitspower and male-to-male adapter
    This is a random scene from a bitspower pr0n site :hehe:
    I will change all the green O-ring to black ones, just ordered some replacements!
    I'm now witing for a lot of bitspower stop fittings and some 90º adapters plus some couplers and "pass through" fittings...
    Next package should have NZXT Fans :clap:
    I think I have to invest In a new camera (using Sony DSC-R1, love it but...)
    Need reflex camera so I can use some sexy macro-lens with it! :idea:
    Also need to get some "portable" lights so I can create better light for pictures!
  10. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    North West England
    Seriously how big is that case? I thought the Lian Li PC77b I have is overkill lol .. thats Mass Genocide ...keeping eye on this build
  11. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Manchester, UK
    LITTLE Angel ? be serious ;)
    Looks like a lovely case, im looking forward to seeing what you get up to inside it !
  12. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Overkill is underrated :naughty:
    The case measures about 70cm height, 23cm wide and 65cm from front to back!
    I also thought that my Lian Li was big btw...
    Thanks for following, hope you like the end result :)
    Case is great, and I know that "little" is false advertising :clap:
    The only "bad thing" are the Torx screws that you have to remove to access the interior but that is something that you won't do on a daily basis once the build is finished :cooldude:
    I think I Will anounce a new sponsor soon so stay tuned :)
  13. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hello everyone! I'm really happy to anounce a new sponsor that decided to help me with my project, It's Seasonic which is going to provide the Little Angel with a Seasonic X-850
    Thank you very much!
    I'm sure you guys already know, but stay tuned because the new PLATINUM SERIES from Seasonic are about to be released! Check it out Seasonic Platinum 1000W
    1. 80plus Platinum-high 92%. efficiency
    2. Fanless mode under 30% load!
    3. 7 years warranty
    4. Launching in November
    5. Available in 860W - 1000W range
  14. Maximilian
    Maximilian WC Virgin
    31 Dec 2008
    Newcastle, UK
    Looking good, subbed!
    Have you checked out Maxishines review of the Little Devil, in Black? (On youtube)
  15. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks!
    Yes I know about Maxishines work and also saw his review, he has a beast not a computer!
    I was thinking getting some black wheels aswell like he did, otherwise the case will be very difficult to handle...
    Last night I did some work on the NZXT fans, I will update the post later to show some of the progress :)
  16. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    UK
    Well I have just found a case to think off when I build my next case.
    This will be watched closely to see how this pan's out.
  17. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    The case is a beast, you can fit another case inside this one :rock:
    Thanks for the following, hope you like it :dremel:
  18. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    [​IMG][​IMG]
    Package from Atlas Informática with lots of NZXT fans. THANKS!
    Family picture!
    I'm working on the fans, removing the sleeving and the speed control that is built in the fan, will post pictures of the process in a couple of hours :lol:
  19. KiiYzOo
    11 Mar 2011
  20. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks! More updates coming...
    Good night everyone, here you have some updates, I've been working on the NZXT fans
    The goal is to remove the speed controler and the NZXT sleeving...
    Very nice sleeving :)
    As you can see the fan speed controler allows you to select between Less - Moar - Hot.... :waah::waah:
    Ok so we get rid of the sticker so we can start working.
    What we want to do is remove the 3 cables on the right side and then solder all the pins remaining together. Doing so the fan will always stay at full speed.
    Aquaero 5 will take control of all the computer fans :D
    Sleeving and speed controller out!
    All this work was possible because of a good friend of mine. Thanks "Lutro0"!
    Just finished 5 fans out of 15... need to keep working :lol:
    Once I finish with all the fans I will have to wait to resleeve them with MDPC and maybe adjust the cable length :)
