2600k - fantastic for BigADV?
Discussion in 'bit-tech Folding Team' started by Ph4ZeD, 3 Jan 2011.
  1. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    As title - huge overclock, low temps and power draw and only slightly slower than hexacores. Thoughts?
  2. cdb
    cdb No comment
    25 Apr 2009
  3. Ph4ZeD
    22 Jul 2009
    Well, remember that the 2500K is not hyper-threaded and thus you couldn't run BigADV.
  4. GeorgeStorm
    16 Dec 2008
    50k PPD? And on a non bigadv work unit?
    Thats pretty mental no? Don't the current i7 9xx (excluding the 980/970) get like 30k?
  5. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    Also when they have not OC'd the 2600 its very similar to the 8 series.... Remember that has a higher stock
    875 is 2.9 stock
    2600 is 3.4 ghz...
    So...
    clock for clock 875 is 15% slower so you would expect 15% difference off the bat
    In seconds 875 took 219 seconds
    2600 took 176 seconds
    IN terms of seconds the 875 does the business 20% slower than the 2600...
    So all things considered on a clock for clock comparison the 2600 is 5% quicker...
    Happy for this to be shot at now :)
    This takes no consideration to bang for buck overclocking, power consunption blah blah blah :)
  6. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    older i7-920-950 should start going cheap soon (wish stupid ebayers would stop biding to retail prices thought anything up to 960 should sell for less then £130 :) as they was 3-4 months before xmas mad prices around that time)
