Case Mod - In Progress Flava Formula
Discussion in 'Project Logs' started by TheL4mka, 29 Feb 2016.
  1. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Flava Formula
    Welcome all at my next project. Cooler Master asked me last year with offer to mod their Master Case Pro 5... So, why not? :)
    I used it for project for ASUS CZ and liked it so much that I have to make one for me too. Therefore, this time not building the case, but edit and rigorous tuning of each part.
    Color theme is clear - black and yellow. Red has been enough, I like yellow ..
    Flava = yellow
    Planning was easier this time because I did not have to invent a whole case :D As you can see on the render I planned mainly inside of the computer. I want the cleanest possible look - cleaner than in previous projects.
    I want to do water loop exactly as in render - only horizontal pipes (I hope it will be possible). For first time I would like to use a bent tubes.
    Materials:
    Especially materials that complete the case.
    - Steel
    - Plexiglass
    - Airbrush paint and varnish
    Plan:
    Edit inside with emphasis on a much greater smoothing interior and a cleaner appearance. The outer part of the case completely airbrush (still thinking about paint and changing my mind every day is different :D) in combination with yellow paint :)
    Components:
    ▪ Intel i7 6700K
    ▪ ASUS FORMULA VIII
    ▪ ASUS GTX 980 Poseidon
    ▪ SSD
    ▪ RAM
    ▪ Cooler Master V1000
    ▪ Master Cooler Master Case PRO 5
    ▪ Corsair AF120 and SP120
    As you can see, I do not know all components for now.
    Everything will be watercooled, as always, for the use of water components from the two top producers - Bitspower and EKWB.
    This project would not have been possible with the support of these wonderful sponsors!
    As regards the actual progress, so that it is not more or less zero :D But! I already have motherboard and case at home. :)
    I will add more soon, probably I will make outside of case first and then through to the inside.
  2. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 1
    I have today the first update - first progress and presentation of case for this project.
    This is Cooler Master MasterCase PRO 5. The latest case from CM. Designed for modders and people who like to do everything their own - "Make It Yours."
    With the partial modularity oof this case you have many choices how to build your PC.
    The front part is perforated and there is a possibility to place up to three 140 mm fans or 360 radiator like me :D
    In the PRO version left side has window, right have not.
    Back side is a classic with the possibility of mounting up to 140 mm fan.
    What I like the most is this part for easy installation PSU :)
    The lower part where is PSU is from the upper beautifully divided right from the CM, which I think is very practical. There are two slots for 2.5 "drives, and cabling.
    Front panel buttons and offers two USB 3.0 ports and two audio jacks.
    To the progress - I took the case to a friend who is devoted to painting etc. I recently built with him a sealed spray booth. The box is completely out of the film and is ventilated. The box has dimensions of 1.9 x 2.6 meters, which is sufficient for our needs.
    Dismantled case - dismantled parts which will be painted and varnished.
    Before painting was necessary paint everything with paint filler.
    After spraying filler came a control spray.
    And then grinding ... A lot of grinding :D
    This look quite good, isnt it? :D Maybe someday ...
    Parts are already back in the box before the first layer of gray metallic. We will continue next weekend! :)
  3. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 2
    In the next update we will stand for a while with the booth. We cut a little window 50x50 cm for easily looking inside. :)
    And also there can be placed a GoPro camera :D
    Regarding the case we painted all parts with gray metallic finish - it was also drama in store with colors to choose :D some nice gray we said, and vendor gave us a pattern and there was about 150 gray :D
    After the gray came the "foil technique". Sprayed with a layer of black and dried by foil several times. In the end, it creates nice structure
    With this technique we have the experience from last autumn, because we made this computer for ASUS CZ :)
    On the side panel will be simple logo. It will be yellow - white - black :)
    The case is now painted at 100%. After the weekend we will polish the parts and I will continue with modding interior. It is like a mirror, isnt it? "Perfect" for photoshoot :D
    One last thing to a workshop was missing .. The holder for spraying guns :D 2 mm HQ steel powder coated.
    At wall :)
  4. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 3
    I have not so much time for modding these days :( ... Normal situation :D Anyway the case is completely painted and is already polished :) Here are the photos. It was also really cool to took these photos because in the clear polished coat reflects absolutely everything :D
    Complete case :)
    The front part will remain so "free", but there will be a radiator fan and finally a bit of yellow :)
    Rear side with the ASUS.
    The front main panel connectors and buttons.
    Although each piece was made separately the texture between different parts altogether builds nicely.
    More coming soon !! :)
  5. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    that yellow logo is gorgeous
  6. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Thanks man!! :)
  7. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 4
    After completion of the outer part, I started working on the inside. I want it inside more smooth and therefore add further steel sheets which will have only those holes that are needed.
    Last week I took case to a small HW event organized by ASUS, so at least I mounted the mobo, res and pump :)
    Sheets, which will complement the interior. Mostly cover sheets
    This sheet is with prepared holes for mounting res without screws. Originally I wanted straight combo pump + res, but finally I decided for this solution :)
    Sheet fits perfectly.
    Back side. Here I will have to do some cuts with Dremel.
    From the bottom of the case, I removed the mounting position for disks ...
    ... and added a cover plate.
    The second plate, yet everything fits perfectly :)
    Sheet around mobo has prepared a straight holes for cabling - better organization of cables that will keep nicely their shape.
    And the back cover from the back side
    I hope in next weeks I will have more time to continue with this mod :)
  8. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 5
    Finally some hardware! For the water cooling. EKWB send me into this project their two radiators, pump and pastel colors for mixing liquid :) For their help they deserve great thanks!
    Raditaror PE360 into front and SE240 into the top of the case.
    D5 pump with PWM control - which is a great thing imo, better than a classic control on D5 pumps.
    Two pure water which will be mixed with pastel concentrates. I took even one orange - I could possibly freshen up :)
    I was quite looking forward to yellow, interesting color :)
    Radiators are well treated and with amazing cooling capacity.
    However, radiators passed the same finish - to match the case.
    Their removal is quite simple, just remove the eight screws and disassemble radiator comfortable, which is great if you decide to paint :)
    Basic gray metallic as well as on the case
    After already known foil technique and finally logo carved through the template :)
    Decent appearance
    There are a few more photos of painted radiators.
    Currently I have still a lot of work with another project but soon I add more! :)
  9. Dragonphreak
    26 Oct 2005
    Is that a 240 (2 x 120mm) and a 420 (3 x 140mm) rad?
  10. CaseLurker
    CaseLurker What's a Dremel?
    15 Mar 2016
    Refreshing paintstyle, that style plus the yellow makes a great combination! I'm subbing!
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Nice paintwork.
  12. Cheapskate
    13 May 2007
    Outer case paint is fantastic. I normally hate logos, but that one is done perfectly.
  13. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    240 (SE 240) and 360 (PE 360) :)
    Thanks for your nice comment! :)
    Thanks!! :thumb:
    Thanks, yea logo is not unnecessarily large or distinctive imo :)
  14. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 6
    Radiators are finished so I can start assembling them in case. First I decided to mod the front of the case.
    360 radiator is the largest rad that can be placed in front position.
    But around rad to avoid unnecessary empty space, so between the radiator and the fans will come this sheet.
    These fans, I have at home and SP version (which better for radiator), but the appearance of the blades is prettier version AF :D I think they could have done it just fine. Anyway, those stickers have go.
    Fans fitted :) Of course, not red, but will go into yellow.
    Almost the entire front of the front.
    The front part is completed by two plates mounted on standoffs.
    More will tell you this render, as I imagined the front part :)
  15. CaseLurker
    15 Mar 2016
    Love those fans, looking forward to the next update!
  16. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Thanks man and here is next update! :D
    UPDATE 7
    Rings of fans has finally got the yellow color. On some of the photos is not well illustrated color, but it's just as yellow as liquid (ie. nice deep yellow) and a sleeving cabling.
    Also on the yellow-painted aluminum L profile.
    Between the radiator and plate I put dust filter, which was originally perforated in front of the case.
    After that plate itself. Incidentally, all sheets are already painted on black matte.
    Installation of fans and tightening spacers, ...
    which are for L-profile and two smaller plates.
    Profile on both sides trimmed front and fine-tune the overall appearance.
    The view from the other side. Input and output of the radiator will be at the bottom of the case.
    But first radiator plate and the fans ...
    and after that the front plastic.
    And finally profiles along with two plates :) The front overall looks good imo, it surpassed my expectations :D
    Next time I want to continue on the inside, not only with the installation of these plates, but also all others.
    The second radiator EKWB SE240 along with fans ready for installation in the upper position.
    When I will recycle the dust filter from the front, so I decided to use even the front grille as a cover. :)
  17. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 8
    After a small break I've got a pretty big update full of photos :) I would like the project completed by the end of June. So now should be more frequent updates.
    Because I decided to do my own holes for cabling, was necessary to make a few notches. And not only for wiring, but also some for reservoir and fittings. I painted edges with black paint to make it clean.
    During the drying paint, I began to mount inside covers to divide the case - a total of 4 plates. One top here
    A second here.
    Together its pretty clean :)
    On the back side, again jsut for finishing appearance.
    Cabling of buttons, USB and audio I hid a little to the left side.
    This is the final appearance of the interior after modding. And we can start with the assembly :)
    As always, I will use water cooling from Bitspower - for the support they deserve great thanks!
    Here are some photos of amazing products, which I'll use in this project :)
    As you can see reservoir will be mounted without screws - only through fittings.
    Reservoir and fittings are prepared, only insert in case :)
    Sits exactly
    Next up was the top D5 pump, also partly predisposed on the table and then just mounted inside.
    TOP is mounted on the bracket with 4 screws.
    Rear side of this section.
    This section, therefore, pump and reservoir, it is completely ready. It lacks only tubing and water :D I will add more soon :)
  18. CaseLurker
    15 Mar 2016
    Black and yellow is so sexy. Love your ideas, looking forward to the next update.
  19. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Thanks man! :) I am doing yellow themed build first time but totally love it!
  20. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    UPDATE 9
    Last week rams from G.Skill arrived. A total of 32 GB of 3000 Mhz. TridentZ are really good and look super, very cool design. They also offer them in other color combinations.
    But watercooling is watercooling :D Here are some photos rams, before dismantling their coolers. Really amazing hiqh quality product
    The original coolers are down.
    Classical installation of water cooling - the two parts, thermally conductive pads, and then 2 screws .
    On this side, I put a sticker TridentZ, let's at least see which beasts are inside :)
    This week I will be doing the sleeving, something I already have, but I will upload it everything together :)
