Guide Time to silence the server
Discussion in 'Modding' started by Barracuda_00, 30 Mar 2014.
  1. Barracuda_00
    Barracuda_00 What's a Dremel?
    26 Jul 2009
    So i have a server since a while back and because of the noise i havent been able to run it 24/7
    and i decided to take care of it.
    :dremel:
    (Cue A-team music)
    I made som fast plans and got a huge sheet of particleboard cut up at the hardware store. Started with 1200mm x 2440mm
    I figure most of you know the art of box building
    Then, 2 pieces to hold the server (foam was placed below to keep server from vibrating) and 2 peices to direct the sound created by the fans.
    More foam to absorb more noise
    Trying to figure out how to add the pieces so as to keep more noise in and airflow above acceptable levels.
    Poor ******* didn't know what hit him
    I´ll be adding some more images later, just a few things left (cut open vents and some more foam) but preliminary testing on the sound is great.:thumb:
    //Cuda
  2. Barracuda_00
    26 Jul 2009
    [​IMG] Moooore foam :D
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Isn't this also going to insulate the server and raise the temps? Thus increasing fan RPM.
  4. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Yes my thoughts aswell. Or worse catch fire.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I think the server would stop working before it got hot enough to catch fire.
    Although as i couldn't see any path for fresh air to enter and stale air to exit it may well get hot enough to cause problems (unless the box doesn't have a top)
  6. Barracuda_00
    26 Jul 2009
    I´ll add a pic in a bit.
    I´ve cut out some sections in 2 boards that will open for airflow but still deflect some of the noises. :dremel:
  7. Pookie
    4 May 2010
    From my experiance rackmount servers are not house friendly in terms of noise. I have friends that just keep them in a garage out of the way. But I'm intrested in seeing how this pans out and fair play for taking the time and sharing with us :thumb:
  8. Barracuda_00
    26 Jul 2009
    There we go, Where at the girlfriends parents and borrowed some tools.
    Made 2 sections that have cutouts for airflow but still add a noise barrier. Gonna cover those 2 parts in foam tomorrow :)
    Will post temps later tonight when esxi is running =)
  9. Pookie
    4 May 2010
    If I ever need a coffin for a dead server i will look you up :thumb:
  10. Barracuda_00
    26 Jul 2009
    Servers been running for an hour tho no vms are active its still looking good :D
  11. Votick
    21 May 2009
    Just out of interest, How loud is this thing?
  12. Barracuda_00
    26 Jul 2009
    Low fan speed and we are talking about an annoyance, at full blast, you need to raise your voice to near shouting level
  13. johnim40
    johnim40 Minimodder
    23 Apr 2009
    could you not just stick it in the roof space/loft
