Guide Guide to taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan
Discussion in 'Modding' started by mnpctech, 25 Nov 2015.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    The Nidec-Servo's Scythe Gentle Typhoon (Model# D122C). This fan has been regarded as the best static pressure optimized fan by DIY PC community since it's release in 2008. The original D122C is no longer made, but there is limited stock available at some online retailers. Last year the D122C Scythe GT fan was resurrected and manufactured as "Darkside Black Edition" by Dazmode. It's the same specs as the original, but now has Black fan blades. Many PC Modders including myself have painted these fans to fit the color schemes of our custom PC builds. I've been asked several times over the years how to remove the metal c-clip without losing or breaking it?*This is my DIY guide to removing and installing external retaining ring or c-clip. Like many others, I've also lost these tiny c-clips while learning the best technique for handling this task.
    Nidec-Servo's Scythe Gentle Typhoon Factory Spec PDF link, http://www.nidec-servo.com/en/digital/pdf/D1225C.pdf*
    Speed: *2150RPM
    Air performance : 68.8CFM
    Nose: 34db (25cm from the fan, free air)
    Power: 12VDC, 0.123A (0.63A peak max)
    Operational voltage range: 5-12V (~900rpm-2150rpm)
    Bearing: Ball
    Expected life: 100000h/35c or 55000h/60c
    Appearance: Full black
    Dimensions: *119 x 119 x 25 mm / 4.68 x 4.68 x 0.98 in
    WARNING:
    Perform this task with Safety Glasses, the tiny Black metal retaining ring (c-clip) can and likely will pop off, so perform this task in a clean workspace, so you can find it. I suggest doing the work on a large white bed sheet and holding a large magnet near the fan hub as you remove and re-install the c-clip, to increase you're chances of not losing the c-clip. I haven't found a source for ordering replacement c-clips yet, but I'm still searching.
    Here is my suggested Tools & Supplies
    Safety Glasses (not pictured)
    Heat Gun for removing the fan label. Hair Dryer on HIGH setting will work as well.
    10" Wire Cable Tie
    Large magnet (not pictured)
    External Fixed-Tip Retaining Ring Pliers, http://www.saeproducts.com/retaining-ring-tool.html
    Tweezers
    Needle Nose Pliers
    Super Glue (not pictured)
    The fan blade looks as if it would snap-on and off, but not the case.
    We need to remove the back label to access the external metal c-clip on the fan shaft.
    Swipe heat gun or hair dryer back and forth over the label.
    Use the Tweezer to peel off the fan label.
    Stick the fan label on a clean metal surface while you perform your work.
    You will tie down the fan hub with this Twisty tie. The fan shaft has a retention spring inside. You need to compress this spring, so you can remove the metal c-clip. If you don't, it's almost a guarantee that the c-clip will fly off the shaft faster than a bullet.
    Using Twisty tie to compress the fan hub spring, by tying down the hub to the fan frame.
    Close ups of the Black metal c-clip inside the Scythe Gentle Typhoon.
  2. mnpctech
    21 Apr 2003
    Insert the two prongs of the Retaining Ring Plier inside the jaw of the c-clip.
    If you have a large Magnet, Position it near the fan hub, just in case the c-clip pops off.
    Holding the black metal c-clip in the Retaining Ring Plier.
    You will widen the jaw of the c-clip and need to bend it back to it's original opening, so it maintains it's grip.
    Hold the c-clip in the Tweezer while using a Needle Nose Plier to compress jaw of the c-clip.
    Doing this will allow you to re-use the metal c-clip.
    Here is the Scythe Gentle Typhoon 120mm Cooling fan dismantled
    If you're wanting to paint your PC cooling fan. You can watch my DIY video guide to painting PC cooling fans
    View of the spring inside the Gentle Typhoon PC Cooling fan, "Be careful, don't lose it!"
    To re-install the metal fan c-clip, grip the c-clip in reverse position on the plier.
    Reversing the c-clip on the plier will make it easier to re-install the metal cooling fan c-clip
    Before releasing the plier, make sure the c-clip is properly seated on the fan shaft, otherwise it will fly off!
    If the cooling fan label has very little adhesion left, I'll apply drops of Krazy or Super Glue to re-apply the label.
    The job is finished!
    Please post other PC cooling fan models you know of that use this same type of metal c-clip
  3. mnpctech
    21 Apr 2003
    Here is another fan I found in our workshop that utilizes the same Black metal e-clip / c-clip. It's a 120mm Delta WFB1212H
  4. mnpctech
    21 Apr 2003
  5. David
    7 Apr 2009
    Nice!
    I just wish I hadn't sold my GT fans. There are very few better out there.
  6. mnpctech
    21 Apr 2003
    Agreed, the GTs are still the best, esp for radiators
