Scratch Build – In Progress Project Aldebaran
Discussion in 'Project Logs' started by gildasz, 24 Jan 2016.
do you think the layot is adequate?
Poll closed 23 Feb 2016.
  1. perfect
    0 vote(s)
    0.0%
  2. usefull
    40.0%
  3. can be improverd
    60.0%
  4. sucks
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. gildasz
    gildasz What's a Dremel?
    2 Jul 2014
    Hello,
    I starded this thread because i've been thinking about my own scratcjh build case for more than one year now.
    my main issue was the purpose of this case.
    for all off you who dreamed about a case that can house big watercooling radiatiors like :
    phobya 1080 and 1260
    watercool Mo-ra 3 1080 and 1260
    alphacool monstas 3x 180
    here are the first picture rendered with solidworks .
    Rad support details:
    For Phobya and watercool : 2 radiators n push/pull
    For alphacool : 4 monstas in push pull configuration
    Plase follow the link below to see he first pics
    https://grabcad.com/library/project-aldebaran-1
  2. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Looks good in the standing position image. The material choice for rendering isn't really helping though.
  3. gildasz
    2 Jul 2014
    Project Aldebaran updated Rendering
    thanks for your comments !
    I have updated the rendering files and also added another case model (Cubical Shape wit more radiators capacity)
    Plase let me know which one ot your attention
  4. HandMadeAndroid
    18 Feb 2005
    Is there going to be a covering for the IO? All the wires coming from the top of the case could look messy.
  5. gildasz
    2 Jul 2014
    yes the to cover model is not ready yet.
    also the 5.25 inch bay at the top will reduce the case length.
    maybe i could modify the radiator bracket to
    handle the wiring?
    also adding a back plate behind the mother board for the same purpose.
  6. gildasz
    2 Jul 2014
    new update
    changed the layout of he 5.25 bay and the design of the fran and rads bracket.
    check the link below.
    i plan to put a small mid play between the radiators area and the top and front 5.25 bay.
    Any idea will be welcomed.
  7. gildasz
    2 Jul 2014
    new update
    radiator bracket added :
    front and rear cover also an 2 drive cages. use the previous link
  8. HandMadeAndroid
    18 Feb 2005
    looking good. Are you planning on using the 5.25 bays? Also I feel the handle lets it down a little. Just the style is quite old. Maybe as an alternative you could incorporate something into the design that acts as a handle or grip?
  9. gildasz
    2 Jul 2014
  10. gildasz
    2 Jul 2014
