Anyone used media money before? I'm looking for a easy to use piece of flac playback software and came across this option. I really like the fact that this can sync between devices. Currently running windows 10 on the desktop and android phone and tablet. Ay others folks can recommend?
never used it but i know a lot of people like it, personally i use foobar2000, its bit trickier to use as you have to install plugins to expand its capability, but if you like to tinker and adjust everything to your liking there's no better music player... from what i've seen i think its a safe bet to install
If you're running 10, Groove will play FLAC... it's a bit on the basic side still but it's there and it works...
I used to use Media Monkey but changed to MusicBee, which I love. It also has a ripping tool in the free version which Media Monkey doesn't.
