Hardware Gigabyte Z270N-Gaming 5 Review
Discussion in 'Article Discussion' started by Dogbert666, 17 May 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Vault-Tec
    30 Aug 2015
    It's nice apart from the fact it honks "orange" and has RGB LED. That is confusing to me. Why tie it to a certain colour combo if you can pretty much light it up any colour you desire?
    It would look lovely in an orange and black build though.
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    I doubt you'll be able to see any of the orange trim once you've filled the board up with GPU, Ram & heatsink.
  4. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Was between this and the Z270 Strix for a while. Settled on the Asus for the more understated look, dual M2 slots and better rear IO connectivity.
    Only complaint I have is the god-awful fan header locations. Literally impossible to get to once you install any hardware!
  5. Combatus
    16 Feb 2009
    It's a tricky call but I'm a little more in favour of going with some sort of colour. The all-black of the MSI ITX board is a little too bland tbh and a splash of colour really helps to boost the aesthetics. I agree about the addition of RGB, though, as as soon as you add colour you lose the colour neutrality so colour matching goes out the window.
  6. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    yeah I'll second this; the AIO "fan" header is almost impossible to get to even before installing anything else; I had to resort to using long needle-nosed pliers to plug that in!
  7. Wakka
    23 Feb 2017
    Yep, which is an ironic oversight as it's the AIO that completely covers it:
    No chance!
    Fan headers should ALWAYS be either on the right hand or bottom edges of a motherboard - IE as far away as possible from any cooler or fans.
Tags: Add Tags
