News Seagate announces first 3.5" hybrid hard drive
Discussion in 'Article Discussion' started by Gareth Halfacree, 7 Mar 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. adam_bagpuss
    24 Apr 2009
    i like the idea but 8GB of Flash isnt anywhere near enough even for a hybrid drive.
    id say a 2TB drive with 32 or 64GB is whats needed.
    Windows 8 is around 15GB isnt it ?
  3. tigertop1
    tigertop1 What's a Dremel?
    23 Apr 2009
    I have already tried a 45GB Accelerator SSD coupled to a 1Gb drive. 8GB is far too small and a minimum of 32 or 45 is really required to make the difference-but 64GB is best of all
  4. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    And how much of that is actually loaded into RAM when you boot your computer? about 1.5->2GB? Add onto that, say, MS office, your steam client, a couple of applications you use the most frequently....and you're STILL not hitting 8GB.
    It's a hybrid. The SSD part doesn't have to hold ALL of Windows or ALL of your Steam library. It just needs the files that you request the most frequently.
  5. alick
    alick What's a Dremel?
    28 Sep 2007
  6. adam_bagpuss
    24 Apr 2009
    This has nothing to do with RAM, windows isnt pre-loaded in to RAM. Windows uses RAM but it doesnt reside there.
    Its exactly as you said most frequently accessed files and guess what windows files are a lot of them as well as the most popular programs you use such as games, photoshop etc 8GB just doesnt cover it
    I like the idea of a hybrid drive but in reality they are arent as good as SSD and command a premium over large storage drives. If i needed both speed and storage id rather have more speed and more storage for slightly more money rather than a compromise.
    seagate hyrbid 750GB 8GB FLASH = £85-90
    64GB SSD + 1TB drive = £90-100
    the separate drives setup is much faster hold more quick storage for critical programs and provides more general storage for more or less the same money !
    Only reason to buy hybrid is for a laptop where space is limited but storage is required. The 3.5" they are going to release needs to be aggressive on price if they are to compete with a separate SSD and HDD setup
  7. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Not meaning to shoot you in the foot for you, but the article is for a 3.5" 2tb drive and not a 750gb and by the sounds of it getting a 1.5Tb harddrive and 64 Gb ssd or 2tb hard drive and a 32gb/64gb ssd is not going to be the same price as a 2tb hybrid somehow ? I do see your point for the lesser capacities, however i havent check that your not just guestimating those figures.
    Its also a space saver not having a 2.5 and 3.5 drives but just one 3.5 drive with no need to any conversion bays, or those using mini-itx cases where one 3.5 drive is suitable - so capacity and speed together are something hard to come by.
  8. adam_bagpuss
    24 Apr 2009
    I used the hybrid drive that you can buy now as i dont have a value for the new 2TB one that the article mentions but hopefully it wont follow the trend of its predecessor and command a big premium over standard HDDs
