Motherboards GA-H67M-D2-B3 - Dual monitor output ?
Discussion in 'Hardware' started by adam_bagpuss, 24 May 2011.
  1. adam_bagpuss
    24 Apr 2009
    hey
    just a quicky as title says does the GA-H67M-D2-B3 support dual output
    there is a DVI-D and VGA connection can i use both at the same time ?
    ive looked over the manual but it fails to mention
  2. Retro~Burn
    Retro~Burn Electronically Debauched Fiend
    11 Sep 2009
    Why don't you try it first? Best bet is to look here:
    Gigabyte
    I'm not sure which revision model yours is so you'll have to check first.
    Are you using an Nvida/ATI card or cards?
  3. adam_bagpuss
    24 Apr 2009
    ive already looked at the gigabyte website
    its rubbish and mentioned nothing about it other than it has DVI-D and VGA outputs.
    not using any thats the point
  4. Retro~Burn
    11 Sep 2009
    You need to provide more detail. Are you only using on-boards graphics or do you also have a graphics card? Have you actually tried connecting two monitors yet? I have no idea what you have or have not done, hence why I need to ask.
  5. adam_bagpuss
    24 Apr 2009
    i havent tried anything as ive not bought it yet.
    all i wanted to know was does it support multiple monitors i know that the SB CPUs support dual display but motherboard makers tend to skimp on costs as much as possible unless its a premium board
  6. Retro~Burn
    11 Sep 2009
    Right, I wasn't sure if you had bought it or were just making an advanced query. Will you be using it for gaming/graphics rendering or just streaming things online?
  7. adam_bagpuss
    24 Apr 2009
    just displays thats all
    directx overlay is the most complicated thing it will do so zero performance needed
