Graphics Really not impressed with the 980
Discussion in 'Hardware' started by Kronos, 5 May 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK after all the discussion concerning the 970 most of which I did not understand but it was enough for me to save a little longer and buy a OCUK GTX 980 http://www.overclockers.co.uk/showproduct.php?prodid=GX-204-OK but I feel that gaming is not as smooth as it was with the cards it upgraded 670 SLI. Games seem to jump about a bit even not exactly graphic intense games such as Timeshift but I have started playing Wolfenstien: The Old Blood and it is decidedly iffy. Framerates seem to jump all over the place from 21 to 62.
    Rest of specs are in my sig and any other info you will undoubtedly want just ask.
  2. GeorgeK
    18 Sep 2010
    Having had a look at the requirements your GPU more than meets the minimum requirements (albeit I'd guess those requirements were for 1920x1080 and you're gaming at 2560x1440) but your CPU is the minimum (well not quite as you've got a 2500k not a 2500) although I really doubt that it's being taxed 100%.
    Admittedly when I was thinking about downgrading my SLI 780s to a single 980 I definitely came to the conclusion that a single 980 was not enough to play every game at its max settings at 2560x1440 - do you have the all the settings turned up all the way?
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    On Wolfenstein, probably George but as I said the likes of Timeshift which is a pretty oldish game (2007) it still is not particularly smooth in parts.
    Should I bench a few games Far Cry 4, Crysis and the like to get an idea. I would hate to think that after spending almost 500 quid I am unable to play games at 2560x1440 on at least high.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    It's probably a daft thing to suggest, but to rule out hardware vs software problems have you tried in safe mode or a selective start-up?
  5. GeorgeK
    18 Sep 2010
    Sorry, I misread your initial post - I thought you said not on older games. Something definitely is wrong as it shouldn't have any issues with games like timeshift... When you installed it did you uninstall and then reinstall drivers etc?
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Sorry do not understand the question.
    I don't think I did seeing as I was going from 670 to 980 both Nvidia I just let Nvidia GeForce experience do it's thing. Was this a mistake?
  7. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Definitely try reinstalling the drivers, Glenn. When I went from a single 680 to the pair, I didn't reinstall the drivers either and it caused all sorts of kooky problems.
  8. Corky42
    30 Oct 2012
    I was just thinking if it could be some background task causing it (AV software, GPU overclocking software) so thought it maybe worth trying in safe mode, or using a selective start-up to rule out non-Microsoft software causing problems.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Will try that then. Sure I have driver cleaner software somewhere
  10. Yadda
    Yadda Minimodder
    25 Jul 2003
    As above, when changing graphics cards, even if they use the same driver package, always uninstall the old card's driver first, then power off and swap the cards, then power up and install the new card's driver.
    As you've already swapped the cards, you need to uninstall the driver, restart the PC and then install the new driver.
    It should be dandy afterwards.
  11. Shirty
    18 Apr 1982
    I reckons you's right.
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
    I was thinking early that you seemed to have been very quite these past few days and as I had not seen an obituary I presumed you were still alive.
    I am downloading as we speak and will remove all traces of Nvidia before reinstalling fresh drivers.
  13. David
    7 Apr 2009
    No need - just run the driver installation and tick "perform a clean install" (then restart, just to be sure).
  14. Yadda
    Yadda Minimodder
    25 Jul 2003
    Handy. Call me old fashioned but I'd still prefer to do it myself. :)
  15. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK, being a belt and braces sort of guy I have followed this and followed Spreadie's advice and doing a clean install.
  16. spolsh
    spolsh Multimodder
    4 Feb 2012
    has it helped ?
  17. Yadda
    Yadda Minimodder
    25 Jul 2003
    You knows it makes sense.
  18. Kronos
    Kronos Multimodder
    6 Nov 2009
    Sorry untested as yet. Could not try it yesterdsy evening but will post back later today once I have fired up Wolfenstein.
  19. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK. Wolfenstien is still pretty rubbish in parts but it is just out so perhaps it is the games fault and not the GPU. Will try Crysis.
  20. Kronos
    Kronos Multimodder
    6 Nov 2009
    Hmm. Benchmarking Crysis I am getting an average of 65DPS which I do not think is to shoddy.
