Case Mod - In Progress InWin DFrame Mini MOD watercooling
Discussion in 'Project Logs' started by PhilipMod, 12 Mar 2016.
  1. PhilipMod
    PhilipMod Minimodder
    3 Mar 2016
    i'm working on a InWin DFrame Mini, I wanna make some different, cut the case and add some parts. You can see the project below.
    let me know what do you think, the project is not drawn at 100% but is my idea of what i'm thinking to do.
    Components:
    Cpu: Intel Pentium G4400
    Motherboard: Asrock H170M-ITX/ac
    Ram: ADATA XPG 2x4gb ddr4 2400mhz
    SSD: 2x ADATA SP900 128gb
    Case: InWin DFrame Mini
    Psu: In Win Classic Series C 900W
    Gpu: Inno3d iChill GTX970 HerculeZ X4 Air Boss Ultra
    Watercooling:
    Alphacool HardTube 16/12mm poleax clear
    Alphacool hard tube 16/12mm fittings
    Alphacool compression fittings 13/10mm
    Alphacool tubing 13/10
    Alphacool NexXxos XT45 Full Copper X-Flow 360mm
    Alphacool HardTube Heat Gun Pro 2000w
    Alphacool 5000ml water
    Alphacool VPP655 pump
    Alphacool NexXxos CPU-Cooler XP-Light
    Alphacool GPU-Cooler GPX-N 980 m02
    Alphacool d-ram module
    Alphacool d-ram cooler x2
    Alphacool Eisbecher 250mm plexi
    Alphacool plexi lighting module
    Alphacool double nipple
    Phobya ZuperZero Collant 1000ml
    Phobya Nano.G 12PWM silent 1500rpm Red Led fans
    Phobya Touch 630 Fan Controller
    Phobya LED-Flexlight
    Phobya RGB-Flexlight Controller
    Phobya radiator stand
    Quick release connector
    UV Grenn/Red fluid
    Monsoon kit for hard tubing 16/12mm
    Saw kit
    SPONSORED BY:
    project (sketchup):
  2. GeorgeK
    18 Sep 2010
    Hello and welcome to the forums! A couple of things to note:
    1) Your first 10 posts / threads will need moderation and so won't appear straight away - there's no need to post them more than once.
    2) When using imgur to host your pics you'll want to use the 'Direct Link' rather than the 'Image Link' or your pictures won't appear (I fixed them this time). Also it's best to use the 'Large Thumbnail' option so your pics don't appear too big here.
    Good luck with the mod!
  3. PhilipMod
    3 Mar 2016
    ok, thanks :)
  4. PhilipMod
    3 Mar 2016
    photos of the case, i have removed all possible parts, is a full modular case like you can see
  5. PhilipMod
    3 Mar 2016
    some photos of the front cutted
    the folds were made by a very special machine that use large companies and it was really difficult to find, more I work on this case and more I think that the welding / assembly / folding method are very very accurate and valid , at the highest levels , a huge congratulations and thanks goes to inwin for this great job, I thank especially for the possibility to working on this product
  6. GeorgeK
    18 Sep 2010
    Your pics are broken (again) - you need to add .jpg to the end or use the imgur direct link - you can edit your post by clicking edit below it.
  7. PhilipMod
    3 Mar 2016
  8. PhilipMod
    3 Mar 2016
    first welds made
  9. PhilipMod
    3 Mar 2016
    creating a lower support on the base of the case to make the structure more solid
  10. PhilipMod
    3 Mar 2016
    i weld the structure to make it more solid, in this days i'll grind the weld to make it uniform with the rest
  11. PhilipMod
    3 Mar 2016
    I grind the weld to make it uniform with the rest
  12. PhilipMod
    3 Mar 2016
    I'm creating a panel that starts from the ex base of the dframe mini to the back, I made the holes for the i/o port of the dframe (see photo) and the second hole is for the fans/pumps controller
  13. PhilipMod
    3 Mar 2016
  14. PhilipMod
    3 Mar 2016
    created the support for the plexiglas
  15. PhilipMod
    3 Mar 2016
    plexiglas cutted, two sides and front done
  16. PhilipMod
    3 Mar 2016
    welded plates and all welds polished, after painting we will see how it will be
  17. PhilipMod
    3 Mar 2016
    Here i am with a new sponsor, Thanks to Asrock for this beatiful motherboard
  18. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    It's the "D-Frame Less-Mini" :lol: Looks like it should shape up to be pretty cool!
  19. PhilipMod
    3 Mar 2016
    thanks, i have some important news to share this week so stay tuned :thumb::rock:
  20. Cheapskate
    13 May 2007
    Neat. :D I like it when people mod an "un-moddable" case.
