RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Oct 2005, 12:50   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
Powerbook disassembly
http://www.bit-tech.net/bits/2005/10...e_apart/1.html
WilHarris is offline   Reply With Quote
Old 21st Oct 2005, 13:08   #2
-Xp-
Supermodder
-Xp-'s Avatar
-Xp- is on a distinguished road
Wow, so it's actually possible to take one of those things apart? Crazy stuff!! It's such an anticlimax to see that there's simply "normal" hardware inside there. I was expecting magical glass tubes filled with blue plasma and lots of shiny round bits everywhere.
-Xp- is offline   Reply With Quote
Old 21st Oct 2005, 13:37   #3
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
It's so sad to think that this actually could qualify as modding for all the work you had to do...to replace a part that should be openly serviceable. Go apple.
That said, good job! Glad it works, and hope you don't keep it on your lap too much...
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 21st Oct 2005, 13:46   #4
ElThomsono
Mod Master
ElThomsono's Avatar
ElThomsono will become famous soon enough
This x-ray's pretty cool:
Shows you how basic the battery really is.
ElThomsono is offline   Reply With Quote
Old 21st Oct 2005, 14:05   #5
RTT
bwarp
Moderator
RTT's Avatar
RTT is a jewel in the roughRTT is a jewel in the roughRTT is a jewel in the rough
You actually wouldn't believe just how abused that laptop is. The pictures do it no justice
__________________
This post is non-negotiable. All terms and conditions apply.
Arguing on the internet is like competing in the special Olympics. Even if you win you're still a retard.
RTT is offline   Reply With Quote
Old 21st Oct 2005, 14:11   #6
Andy Mc
Supermodder
Andy Mc is a splendid one to beholdAndy Mc is a splendid one to beholdAndy Mc is a splendid one to beholdAndy Mc is a splendid one to beholdAndy Mc is a splendid one to beholdAndy Mc is a splendid one to beholdAndy Mc is a splendid one to behold
FYI: the wall paper in the last shot is another from little-gamers.com
__________________
"Seemed a harmless little ****........But we unleashed the lion"
'Jeremy' by Pearl Jam
Andy Mc is offline   Reply With Quote
Old 21st Oct 2005, 14:18   #7
Godboy_g
Supermodder
Godboy_g's Avatar
Godboy_g is on a distinguished road
Since you already had the case apart, you should have painted it..... It would look sweet with the Bit-tech logo on there.
__________________
I AM Backwards compatible!
Godboy_g is offline   Reply With Quote
Old 21st Oct 2005, 15:14   #8
xheadinthecloudsx
What's a Dremel?
xheadinthecloudsx is on a distinguished road
Disassembly/repair guides for most powerbook/ibook models can be found on: http://www.pbfixit.com/Guide ... and they show you how to open it up without damaging the front of your optical drive.
xheadinthecloudsx is offline   Reply With Quote
Old 21st Oct 2005, 15:20   #9
r00t69
Multimodder
r00t69 is on a distinguished road
__________________
Pitch Black
I always said I wanted to be someone, I just should have been more specific!
r00t69 is offline   Reply With Quote
Old 21st Oct 2005, 15:33   #10
Deep-Blue
Part-time Overclocker
Deep-Blue's Avatar
Deep-Blue is on a distinguished road
I feel your pain dude. My Powerbook 12" is starting to get a bit sluggish and occasionally doesn't boot either. Having said this, i think i still have the extended warrenty on this, so i may just have to give em a call.
Oh BTW, kudos on the great choice of wallpaper. Its funny how LG wallpaper and Macs just go hand in hand!
__________________
[iMac C2D 2.4Ghz - 4Gb Memory 667Mhz - 320Gb HDD - 10.5]
[Lenovo M55p Tower - Core2Duo E6300 1.83Ghz - 6GB DDR2 6400 - GeForce 7800GTX]
Deep-Blue is offline   Reply With Quote
Old 21st Oct 2005, 16:04   #11
Shadow_101
Mudkips.
Shadow_101's Avatar
Shadow_101 is on a distinguished road
is that just 8 AA batts?
__________________
Network Engineering & Security, CCNA, ITIL (F).
GM IT Security Analyst
Shadow_101 is offline   Reply With Quote
Old 21st Oct 2005, 16:07   #12
ElThomsono
Mod Master
ElThomsono's Avatar
I don't think so, they're too big (using the HDD as a scale). Just that they've soldered together a load of cylinders and stuck them in a square box, not very space efficient
Old 21st Oct 2005, 16:39   #13
Gordy
Evil Teddy
Gordy's Avatar
Gordy is on a distinguished road
That poor powerbook. Don't know how you can give so much abuse to something that expensive
__________________
modding.gordyhand.co.uk
Gordy is offline   Reply With Quote
Old 21st Oct 2005, 16:41   #14
Arkuden
mow?
Arkuden's Avatar
Arkuden is on a distinguished road
no you can see the standard battery plugin the top right of the rectangular area that those tubes or cells cover. 8 cell battery i would imagine. At least ive heard of them being referred to as such becuase you can get an optional 12 cell battery with laptops as an option these days.
Arkuden is offline   Reply With Quote
Old 21st Oct 2005, 17:19   #15
phantomxc
Multimodder
phantomxc is on a distinguished road
If you think it was hard to get that thing open, try taking out a logic board and putting a new one in.
__________________
?AMD Athlon 64 3500+ Venice?Sapphire X800 XT PE ?Abit AV8?1 gig 3200 giel?160 GB Western Digital 7200
FRIED EVERYTHING...
3DMark05 = 6306?
"Last week, Japanese scientists placed explosive detanators at the bottom of lake Loch Ness, to blow Nessie out of the water..." Napolean Dynamite
phantomxc is offline   Reply With Quote
Old 21st Oct 2005, 19:08   #16
Meanmotion
Supermodder
Meanmotion's Avatar
Meanmotion is on a distinguished road
That's what all battery packs are - powertools, laptops, cameras, etc. That's why it's such a swizz when they charge you loads for them - and you know what it's not even the cells that go it's the controller boards on the packs.
__________________
Athlon64 X2 4400+ || A8N SLI Premium || 2Gb Corsair XMS Pro || 2*40Gb Raptor (striped) || 250GB External || Radeon X1950Pro || WinXP
www.OutForBlood.co.uk || www.4Qradio.com || www.EdwardChester.co.uk
Meanmotion is offline   Reply With Quote
Old 21st Oct 2005, 19:08   #17
DreamTheEndless
Gravity hates Bacon
DreamTheEndless's Avatar
DreamTheEndless is on a distinguished road
...As I've been saying for years. SDRam, now DDR and DDR2 (ecc or not); scsi, IDE, sata; usb; pci; agp; pci-x; pci express....
My (now gone - donated to a good cause) beige 300mhz g3 powermac took SDram and had a pci video card. I know a long time ago they used different hardware than most of the x86 world, but times have changed.
And yet - you still have people who say you shouldn't buy a mac because you can't upgrade them or can't find parts for them......
I bought new ram for my sisters clamshell (toilet seat cover) iBook in the electronics section of the grocery store!!
Yes - it's the same hardware.
Sorry - just realized this was a rant and didn't mean it to be. It's just that this is a conversation that I have had too many times over the last several years. I have counted to 10. I am calm now. I swear.
(It's the same hardware.)
__________________
Srenob is deader than dead, so check out my new blog instead:
http://i-have-a-blog-now.blogspot.com/
(Note - there's not much there yet, but maybe there will be someday.)
DreamTheEndless is offline   Reply With Quote
Old 21st Oct 2005, 19:28   #18
ElThomsono
Mod Master
ElThomsono's Avatar
Yeah, but at least on my laptop they've accepted it, the battery pack looks like 2 long cylinders side by side, a sort of 8 shaped prism.
But yeah, batteries are a huge rip off
Old 21st Oct 2005, 19:28   #19
joshua
What's a Dremel?
joshua is on a distinguished road
Good to see you picked a non-Toshiba drive, crappy crappy drives. Not a lot of joy explaining to a user the benefits of loosing 5-7 years of email/files and to look at the positive benefits of the situation. To see the situation as a kind of data enema cleansing the bowels of their laptops.
I've had to do this today due to the failure of the same exact model drive you had, and replaced 20 over the last year. luckly toshiba's and hp's only have 2 screws holding drives in, makes replacing far easier.
joshua is offline   Reply With Quote
Old 22nd Oct 2005, 11:13   #20
BurntKona
What's a Dremel?
BurntKona is on a distinguished road
Nice work disassembling. Got to do the same myself with an Acer Aspire 1500. I guess it isn't only Apple that doesn't believe in making things easy for the techy user to repair.
And it was a Toshiba drive that went Kaputt. 17 months old. At least it hinted at impending doom and back-ups were up to date.
BurntKona is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
