#1 |
Geoff Richards
Moderator
F.E.A.R. Graphics and Gameplay
#2 |
CAMRA ***.
ooo the game does look pretty, it just appears that I had my settings all completely wrong!!
This sort of review is really good for someone as lazy as me as I had initially rejected FEAR on the grounds that it was jaggy and plain and couldn't be bothered to fiddle with the settings! It looks like I am just about to lose my social life for a few days!!! doh! |
#3 | |
Geoff Richards
Moderator
What did you have your settings set to mate? On what sort of system? To be honest, the Auto Detected settings are a little conservative - I only lost 2fps by enabling 2xAA yet benefitted massively in terms of image quality as a result.
#4 |
Supermodder
So can we infer from this review that the graphics settings should be roughly equivalent to that of the demos? You guys didn't really cover my system. 4000+ and X850XTPE doesn't seem to really mesh with any of your choices too well, oh well, that's what demos are for.
__________________
If you made a Venn diagram, there would be two non-overlapping circles, one of which was labeled, “Times when I am truly happy” and the other of which was labeled, “Times when I am logged in as root, holding a cable, and have the case open.” |
#5 |
Geoff Richards
Moderator
Well Reaper, it's possible to fill in the gaps using the existing data. A 4000+ is a bit faster than the 3700+ system, and a X850 XT PE is a bit faster than the X850 XT tested.
I played through the game on a 2.2GHz P4 but with a X850 XT PE and managed 1024 2xAA well enough. It wasn't 100% smooth all the time, but any stutters didn't impact on the gameplay, just a brief pause when entering a really big room etc Certainly tolerable. I think you'll find that you could run 1024 2xAA smoothly; perhaps 1024 4xAA as well. 1280x960 0xAA should also be doable, according to Tim's numbers. At outside bet would be 1280 with 2xAA - the visuals will be crispy, but it may or may not be 100% smooth depending on your standards. Tim doesn't settle for anything less than super smooth, but some people like me can tolerate the odd stutter. |
#6 | |
Pewlius Caesar
bit-tech Staff
My suggested settings for all of the video cards we tested should be pretty conservative and you can increase them a little if you don't mind a bit of lag here and there.
__________________
#7 |
Geoff Richards
Moderator
Oh yeah, I forgot to mention Detail: you can have a mix of Medium and Maximum. Have a play to decide what you think is important. Max Particles looks so cool, but gets in the way of the gameplay a little when you can't see what you're doing
#8 |
Natural Born Chaos
Looks like my card is gonna have to go soon! Doh..
__________________
Steam: kev_fury New Frag Video- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston - - Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA - |
#9 |
Moderator
This has just tempted me to get a 7800GTX instead of a GT, oh well. I look forwards to playing the game!
__________________
Project Red - HL2 - PSOne LCD S-Video Guide
Main Rig: Asus Striker Extreme, Intel Core 2 Quad Q6600 G0 OC'd to 2.65GHz, 4GB Corsair XMS, 8800GTS in SLI, 36 & 74GB Raptors |
#10 | |
CAMRA ***.
My system is DFI SLI-D, AMD64 3000+ (venice) @ 2.7GHz, 1GB Mushkin Redline, 6600GT etc etc so although it's not great, i expected more from FEAR than i got! |
#11 |
Licenced Fool
even on my aging xp2600 1gb ram with an fx5500 its playable (autodetected as a meduim spec machine), frame rates are a bit low but with some tweaking of the detail levels even a modest machine like mine will play it quite happily, time for a new gfx card tho ,going to have a little overclocking sesh to see if I can get it running a tad faster whilst i raise some cash
and you're right the AI is simply amazing |
#12 |
What's a Dremel?
hmm .. different setting for me for 6600GT
i have a much lower specced system than the testbed AMD 3200+ (2.0ghz) Venice ASUS A8V Deluxe // AGP , also using onboard sound BFG 6600GT AGP (525/1050) Kingston value dual channel DDR400 512mb x 2 7200 Rpm WD IDE Hd... freshly installed pc anyways i play on 1024x768 0xAA 8xAF , no SS, every other option enabled to maximum (sound, cpu etc) except Medium Textures Medium Shaders.. performance decreases too much for my card when i put Max Textures.. i never tried full shaders though runs smoothly for my taste.. i lower settings abit for multiplayer |
#13 |
Multimodder
am i stupid or is the computer specs not listed..i see the video cards but not the specs of the comptuer..thanks
| boardsportsrule |
| View Public Profile |
| Find More Posts by boardsportsrule |
#14 |
Supermodder
Using the built in test, my system gets
Minimum 24 average 43 maximum 98 1% below 25 fps 51% between 25 and 40 fps 48% above 40 fps My settings are: Effects Detail Maximum Model Decals Medium Water Resolution Maximum Reflections and Displays Medium Volumetric Lights on Volumetric Light Density Medium FSAA 2x Light Detail Medium Enable shadows On Shadow Detail Medium Soft Shadows Off Texture Filtering Anisotropic 2x Texture Resolution Medium Videos Maximum Pixel doubling Off DX8 Shaders Off Screen Resolution 1024x768 Shaders Medium In the advanced computer options, everything is at max aside from sound and particle bouncing, those are at medium. I think these settings look pretty good, and the game plays nice and smooth. I believe I have room for upping something, what can I up that would be the most noticable without going too far?
__________________
-The 500w Shuttle-, SN95G5, AMD3500+, msi 6800gt, 2x512mb ballistix, 200gb Seagate (sata), audigy 2zs, 500w internal psu |
#15 |
Multimodder
Eeeek! You linked to the Multiplayer Demo instead of the Single Player one!
__________________
abit IP35 Pro|E6600@3.3|7900gs@585/780|2GB Corsair DDR2 800|WD 250GB|X-Fi XtremeGamer|Zalman VF-900|Modded Zalman CNPS9500
#16 |
99.999% Pure Spam!
I downloaded the MP demo a few weeks ago and this just promted me into installing it. Spent 20 mins setting up the gfx to get them to the best possible quality without too much performance drop (Will post settings tomorrow). I decided to make a server to explore the maps and get a feel for the game as i do with every game, The server filled itsself up, so i ended up running a server for 5 hours hauling some serious ass and really getting into the game! Really is a cool game.
(sorry )
__________________
I got told to change my signature. So i did. Last edited by P2D; 25th Oct 2005 at 02:11. |
#17 | |
Geoff Richards
Moderator
http://www.bit-tech.net/gaming/2005/10/24/fear/4.html High-End System Setup: AMD Athlon 64 X2 4800+ (operating at 2400MHz, 12x200MHz); DFI LANParty nF4 SLI-DR (NVIDIA NForce4 SLI); 2 x 1GB Corsair XMS4000 Pro (operating in dual channel at 200MHz with 3.0-3-3-10 timings); Western Digital Raptor 74GB, 10000RPM SATA 150 Hard disk drive; OCZ PowerStream 520W Power Supply; Windows XP Professional Service Pack 2; DirectX 9.0c; NVIDIA NForce4 Standalone chipset drivers, version 6.66. |
#18 | |
Pewlius Caesar
bit-tech Staff
__________________
#19 |
What is a Dremel!?
Moderator
This game is indeed hungry
![]() I can run with everything on max @ 1024x768 except anisotropy at 8x and Soft Shadows off. Specs in sig.
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#20 |
Multimodder
Top review again guys.
If I wasn't knee deep in Matrix Online I'd buy it. I might download the Demo and see how a 3800+/2GB/6800U SLI rig handles it though.
__________________
Pitch Black I always said I wanted to be someone, I just should have been more specific! |
| Thread Tools | |
