#1 |
Minimodder
Akasa AK-920 EVO 120 or VapoChill Micro Ultra Low Noise
Hi guys.
I'm currently deciding between an Akasa AK-920 EVO 120, or VapoChill Micro Ultra Low Noise for cooling ana thlon 64 x2 (most likely the 4400+). The primary goal for me is low noise (the Akasa seems to be best for that). Has anyone actually used either of these for this processor? Also, I have a Lian-Li V1000B and Im a little worried about the fins on either HS protruding outside the area of the motherboard. The right hand edge of an ATX mobo (looking from on top) sits right up against a panel on this case making little room around the cpu; so large heatsinks that run over the edge of the mobo wont fit into the case .I havent managed to find any really comprehensive reviews on either HS, so I'm wondering what opinions and experiences people have. |
#2 |
Disgruntled kumquat
I know for a fact that an XP-120 will fit on an ASUS A8N-SLI in a V1000, if that's any help.
#3 |
Supermodder
wasn't xp-120 the "pin bender"?
#4 |
Ultramodder
It mounts useing the holes on the motherboard, much like every other aftermarket hs. I'm sure if you epoxied it to your cpu it might bend the pins when you try to remove it.
#5 |
Supermodder
heeh... now I remember... it was the thermalright xp120 that had crap mounting which bent the cpu pins when you took it off
#6 | |
Minimodder
I haven't had a chance to test the heatsink yet, but when I do I will post to let you guys know just how good it is. I hope my descriptions above aren't too confusing and that this helps anyone who had simillar questions to this one. |
#7 |
What's a Dremel?
Does it fit the A8N32 SLI DELUXE??
I really like the look of the Akasa AK-920. Does the fan and heatsink get in the way of the on board heatpipes of the ASUS A8N32 SLI DELUXE or do they have to be tampered with to install the fan? Thanks in advance,
Slave .
#8 |
Last Of The Dovakhiin
Don't get the vapochill micro, it's utter *****
either the akasa or AC freezer for low noise [EDIT] OOPS, just noticed, this is an oooollld thread [/EDIT] QUIT DRAGGING UP OLD THREADS *SLAP*
__________________
"Don't Fear Citizens! TAD KNOWS HIS RAID!" - Bindi MAIN BOX E7400|HD5770|Viewsonic VX2260WM|Asus Xonar D2X|4GB Dominator|Samsung F3 1TB|Gigabyte GA-EP43-S3L WIN98/DOS GAMES BOX 1GHz P3 Coppermine|GF3 Ti500|Creative Live! 24-bit|256MB Rimm|WD 10GB HDD
| Tags |
| cooling |
| Thread Tools | |
