RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Nov 2005, 17:02   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
ECS KN1 SLI Extreme
http://www.bit-tech.net/hardware/200...extreme/1.html
Tim S is offline   Reply With Quote
Old 18th Nov 2005, 19:50   #2
Arkuden
mow?
Arkuden's Avatar
Arkuden is on a distinguished road
good review. Other than the Lan problem... it looks to be a fairly solid board but I would still feel kinda iffy about getting it becuase of all the other well known and trusted names that are right at that price range as well. If it was a more competative price I think i would go for one.
Arkuden is offline   Reply With Quote
Old 18th Nov 2005, 20:02   #3
dire_wolf
Revelation Machine
dire_wolf's Avatar
dire_wolf is on a distinguished road
2 40mm fans !?!?
thats got to sound awful
__________________
Marching Into History, Marching Into War, Marching Into History To Function As A Whore
"Don't Fear Citizens! TAD KNOWS HIS RAID!"
dire_wolf is online now   Reply With Quote
Old 18th Nov 2005, 20:56   #4
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Originally Posted by dire_wolf
2 40mm fans !?!?
Yeah, it's quite loud on an open bench. It'd make sense if it had a heatsink above the PWMs and the 40mm fan running a little slower - it'd improve efficiency a little bit.
Old 18th Nov 2005, 21:16   #5
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
2 40mm fans !?!?
You can unscrew and completely remove the one on the IO at least but the NF4 one is to be expected, all NF4 mobos have that.
Bindibadgi is offline   Reply With Quote
Old 18th Nov 2005, 21:18   #6
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
unless a heatpipe solution is implemented (like on ASUS and ABIT's latest boards).
Old 19th Nov 2005, 01:15   #7
bigapl
What's a Dremel?
bigapl is on a distinguished road
Thats wierd about the 8X PCI-E mine runs full 16X with 6800 or 7800GT and 8X by 8X in SLI maybe there is a BIOS update you need?
bigapl is offline   Reply With Quote
Old 19th Nov 2005, 11:04   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
No, there's no selector card so it's set to only run in 8x8 whether you have 1 card or 2.
Heatpipes not only have to be invented in such a way so that they dont infringe on patents like ABITs OTES but they're also expensive compared to a fan
Old 19th Nov 2005, 11:14   #9
bigapl
What's a Dremel?
There must be a problem with that board I checked 2 other systems I have built with it and they are all running nat 16X with one card.
I have read about 6 or 7 other reviews and yours seems to be the only board that does this 8X in single card mode.
Old 19th Nov 2005, 12:19   #10
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Ive not got the board here now, but I checked NVIDIA's display control panel and it said x8 when in single card mode. There's no card or digital switch like the MSI SLI boards for selection either.
Old 19th Nov 2005, 12:38   #11
bigapl
What's a Dremel?
Thats wierd it might be some sort of glitch I havent seen on this board before, so far I have had good luck with them and all mine run 16X.
Did you get with ECS about that?
Old 19th Nov 2005, 13:21   #12
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Did i discuss it with ECS? No. Because it has no selection method - digital or card switch like normal SLI I assumed ECS saved money and didnt include one but just hardwired it to always be in dual x8 mode. NVIDIA control panel confirmed this to me and I didnt think anything more of it.
I didnt check it with any other drivers other than 71.89s, but what does your NV control panel say?
Old 19th Nov 2005, 14:13   #13
bigapl
What's a Dremel?
Mine says 16X with both the 6800 and the 7800GT and 8X in SLI maybe it is some sort of driver issue.
Old 20th Nov 2005, 09:39   #14
chrisuk
Modder
chrisuk is on a distinguished road
The ECS KN1 SLI Extreme is a reasonably full-featured motherboard that fits into the cut down, value territory that is occupied by the likes of ABIT, ASUS, DFI and Gigabyte, so there are some choices to be made.
So why was this board not compared to any of these maufacturers? Surely that would have been more useful.
chrisuk is offline   Reply With Quote
Old 20th Nov 2005, 11:21   #15
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Because we arent provided with those boards. We have to use what we are given unfortunately
bigapl - im gonna get in contact with ECS and ask them how their SLI switch works because it's beyond me as there's no physical evidence of a switch on it.
Old 20th Nov 2005, 12:14   #16
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
nice looking board with less features I wouldent use. After fiddling with a lan party it's a very nice board but has so many features that the bios takes a few weeks to setup proporly.
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 20th Nov 2005, 12:46   #17
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
We have a review of another SLI motherboard in this price range coming soon.
Old 21st Nov 2005, 05:15   #18
Anakha
Supermodder
Anakha's Avatar
Anakha is on a distinguished road
As a comment on the "Computational error" with the SLI/Non-SLI results, here's an idea on how to get the best result.
Run the same test 5 times, discard the top and bottom results, and average the remaining three. That way one-time statistical anomalies don't affect the outcome (As the worst and best are discarded to get a true "Average" result).
I realise this will take a little extra time to do, but it will give you a more accurate result, and a result you can more easily compare with other results.
Just my £0.02
__________________
Robert "Anakha" Johnston
Going to Canada on Nov 28th! I'm going home!
Anakha is offline   Reply With Quote
Old 21st Nov 2005, 10:17   #19
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
That is a standard benchmarking practice as it is - ensure that all results are repeatable.
Old 21st Nov 2005, 13:12   #20
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Because it's real world nothing is ever exact unlike a benchmark which is specifically designed for an uber accurate result. For things like the performance %age of WMP HD it's just windows cpu monitor is used and it's run for a while on loop and the most suitable average is taken. On other things that has human influence, like timing of the batch jpg/bmp encoding i take an average.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
