Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 28th Nov 2005, 21:14   #1
Nikumba
Hypermodder
Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.
Variable Voltage Relay
Im no sure if a relay like this exists, but I want a relay that will work with varying voltages.
So if a voltage is passed over it, it switched on
Cheers
Nikumba
Nikumba is offline   Reply With Quote
Old 29th Nov 2005, 00:04   #2
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
Give us an example.
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 29th Nov 2005, 00:31   #3
gulp35
Multimodder
gulp35 has yet to learn the way of the Dremel
Why not use a comparitor circuit. The easiest way is to use an op amp. Set it so it doesn't "turn on" until you exceed some set voltage. Then set the output to control your "relay". You may need a SCR or transistor to handle the load of your relay coil, as it may be to much current for the op amp to supply on its own.
__________________
MAIN:--Epox 8RDA+ v1.1--TbredB 1700+ 2500MHz@1.792v[SwiftecMCW6002&DannerMag3Pump]--2x256MB Kingston PC3000 2-2-2-8
&nbsp --ATi Radeon 9800Pro[Copper 1U Heatsink]--WD800JB+WD2500JB--Sony DVD/CDRW--Forton350W
Mods: HAL|9000-A 2U mod Odyssey --- Custom Wooden Cubish Case --- "Mission" Impossible HTPC --- MI Discussion Thread
gulp35 is offline   Reply With Quote
Old 29th Nov 2005, 09:27   #4
Nikumba
Hypermodder
Originally Posted by cpemma
Give us an example.
Basically i want to be able to turn a motor on when a battery gearbox is started but since its battery powered the voltage drops over time hence a 12v relay would onlyu work for so long before not working
Nikumba
Old 29th Nov 2005, 13:14   #5
cpemma
Ecky thump
cpemma's Avatar
Most 12V-coil relays will work fine down to at least 9V supply. If that's not low enough for you, use a 6V relay with a 5V LM7805 regulator on the battery (and a protection diode across the relay), that will work with the battery down to around 7V.
__________________
Nobody's perfect.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
