Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 14th Jun 2002, 12:31   #1
Adam
Mod Master
Adam has yet to learn the way of the Dremel
Joining COAX cable (very dumb question)
<short version> How do you join 2 pieces of coaxial cable?</short version>
<long version> Moving my sky box from one room into another, need to extend the cable. I can't get to the dish to just put a new cable on because of where it is located. So what's the best way to join one piece of cable to another to extend it? Also, where is the best place to get satellite cable, I've tried all the shops around here and nowhere has any!
__________________
www.tsohost.co.uk - proudly hosting bit-tech.net
Adam is offline   Reply With Quote
Old 14th Jun 2002, 12:36   #2
RTT
#parp
RTT's Avatar
RTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming SaiyanRTT is a Super Spamming Saiyan
Use two male plugs on both ends of the coax, and then you can buy an adapter which is a double ended female plug, so each male plug fits into both ends.
Slight loss of quality, however you could always just buy a new, longer cable.
/goes to get pics
RTT is offline   Reply With Quote
Old 14th Jun 2002, 12:49   #3
Adam
Mod Master
Any idea where I would buy these? Must be online, nowhere here sells them. I miss Tandy :cries:
Btw, can't just put a longer cable on because I can't get to the dish to attach it.
__________________
Old 14th Jun 2002, 19:58   #4
rK@NE
Rover's gonna get it...
rK@NE's Avatar
rK@NE has yet to learn the way of the Dremel
You can get em at Maplins
rK@NE is offline   Reply With Quote
Old 15th Jun 2002, 00:36   #5
felix the cat
Spaceman Spiff
felix the cat's Avatar
felix the cat has yet to learn the way of the Dremelfelix the cat has yet to learn the way of the Dremel
any decent hifi shop should sell em...
__________________
...wordEs...
felix the cat is offline   Reply With Quote
Old 15th Jun 2002, 01:11   #6
macroman
The One
macroman has yet to learn the way of the Dremelmacroman has yet to learn the way of the Dremelmacroman has yet to learn the way of the Dremelmacroman has yet to learn the way of the Dremelmacroman has yet to learn the way of the Dremelmacroman has yet to learn the way of the Dremel
The cable from the dish uses "F" connectors which are not the connectors in RTT pic. Do a search for "F" connectors on Maplin or RS. Or if you prefer, B&Q/Do-it-All sell them.
__________________
TIME is like a train up your ass, It keeps pushing you forward. When you hit the buffers it's game over.
macroman is offline   Reply With Quote
Old 15th Jun 2002, 21:57   #7
Forsaken
GameFaction.com
Forsaken has yet to learn the way of the Dremel
B&Q also do the digi satellite cable too (well one of mine does)
__________________
GameFaction - For all you gaming needs.
Forsaken is offline   Reply With Quote
Old 15th Jun 2002, 23:31   #8
Fly
inter arma silent leges
Fly's Avatar
Fly has yet to learn the way of the DremelFly has yet to learn the way of the DremelFly has yet to learn the way of the Dremel
I make two or three cables like this up a day in maplin.
the parts you need are
2 x FU04 - Screw on F Connectors
1 x FE92 - F Double Female
however many metres you want of XS16 (Black) or XS17 (White)
__________________
"Flying is simple; push on the stick and the houses become bigger, pull back on the stick and houses become smaller, unless you keep pulling in which case the houses will become bigger again..."
Fly is offline   Reply With Quote
Old 16th Jun 2002, 02:43   #9
felix the cat
Spaceman Spiff
i used to sell these at work...
__________________
...wordEs...
Old 16th Jun 2002, 10:46   #10
yodasarmpit
No longer the other Brett.
yodasarmpit's Avatar
yodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyan
Try to get hold of CT100 cable as that is what they use to connect from the dish to the box , if you use ordinary coax from the likes of argos etc you will see a drop in picture quality.
If you do use the f connector from the dish be carefull not to move the dish as it only needs to be slightly out of alignment to loose signal quality.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
yodasarmpit is offline   Reply With Quote
Old 16th Jun 2002, 21:25   #11
Adam
Mod Master
Thanks fly, you've done all the work for me! I will try and get the proper satellite COAX but its a digital system and the signal quality is on 1 bar from max at the moment, so if it falls a couple of bars it wont make a difference to anything. My grandad in Spain uses it and his is on 2 bars quality + strength and the picture doesnt suffer from break up.
__________________
Old 16th Jun 2002, 22:07   #12
Fly
Fly's Avatar
that is CT100, proper satellite cable BTW.
__________________
Old 16th Jun 2002, 22:55   #13
samuelellis
I Mod, Therefore I Own
samuelellis has yet to learn the way of the Dremel
i guess i lucked out when i wired up the old anologue system in my room by fnding 500m of sattelite cable in our garage with all the pieces, jsut long enough to run the dish from our garage all the way from one end of the garden, to my wall, up & in my room(guess it pays to have a horder as a dad)
__________________
http://www.realmofexcursion.com/ - click me, im funny
samuelellis is offline   Reply With Quote
Old 16th Jun 2002, 23:00   #14
samuelellis
that is more true with digital systems as on anologue if you could put up with the odd sparkalie (thats a technical term ) on some of the weaker broadcasting channels then you did not have to be as exact but as digital uses a smaller dish & you ether get a good pic or no pic you hreally have to be precise but if you want to track down one of the old style dishes & use that with your lnb you can set a better signal as it has a wider catch.
__________________
Old 17th Jun 2002, 21:05   #15
GiGo
was once a nerd.....
GiGo's Avatar
GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.GiGo is definitely a rep cheat.
Wilko will sell um. Very cheap as well. less than a 1 for 3 connectors.
__________________
Wow I was once a nerd and listed all me 'High Spec' stuff here
So what do I own now.......
1x Synology DS1815+ RAID6 36TB NAS + 1x Generic RAID5 3TB NAS, MS Surface Pro 3 i7, Google Glass XE2.0, loads of other none describe tablets/laptops/phones/chromebooks etc.... oh a **** load of spare cables
GiGo is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
