RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Jan 2006, 06:48   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
AMD Athlon 64 FX-60
http://www.bit-tech.net/hardware/200...4_fx-60/1.html
Tim S is offline   Reply With Quote
Old 10th Jan 2006, 06:58   #2
Boswell
Eddy-B
Boswell's Avatar
Boswell is on a distinguished road
{i knew it ..} its not like a killer cpu where its on top for everything but its certainly another step forward (imo) into the lead.
__________________
||Q6400@3.6Ghz|8800GT|4GB Ram|2TB||
Boswell is offline   Reply With Quote
Old 10th Jan 2006, 07:05   #3
Pookeyhead
It's Big, and It's Clever
Pookeyhead's Avatar
Pookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to all
I actually didn't sleep too well thinking about this chip!!!
I can't believe you didn't clock it!!! That's what I wanted to know!!
Still... Over £600... not too bad really.. I was expecting over £700 like when the FX57 was launched.
I was dissappointed to see the FEAR results... that's my main game at the moment (hence my absence from the CS:S server). I do plan on buying quake 4 however, and it seems to rock with that.
Do you still have the chip Tim? Can you clock it? Will it do 3GHz? Weird isn't it... once you've had a chip that does 3GHz, you can't seem to drop below that number ever again... kind of a psychological thing.
I'm getting one of these chips.
__________________
Intel i7 920 @ 3.8GHz ¦¦ Asus P6T Deluxe ¦¦ 6Gb Corsair Dominator C8 ¦¦ XFX GTX295 ¦¦ 2x 1Tb Samsung F1 ¦¦ 1x Seagate 7200.11 1.5Tb ¦¦ Gigabyte Odin 800W PSU ¦¦ Dell 2405FPW.
Pookeyhead is offline   Reply With Quote
Old 10th Jan 2006, 07:59   #4
Hybr1d
Bаnned
Hybr1d is on a distinguished road
Originally Posted by Pookeyhead
Still... Over £600... not too bad really...
*learns the art of pro photography*
Hybr1d is offline   Reply With Quote
Old 10th Jan 2006, 08:04   #5
Highland3r
I Mod, Therefore I Own
Highland3r is on a distinguished road
600 quids pretty cheap tbh, was expecting the chips to be other the 1k mark...
Resuilts arent hugely surprising, its basically an overclocked 4800 with unlocked multi's... Would be nice if you can give it a quick once over on the performance enhancement side tim, see if you cant squeeze a little more out of the chip.
Out of interest, what sort of temps are you seeing with the chip at stock? Idle/load etc..?
__________________
Prawn or not...?
Highland3r is offline   Reply With Quote
Old 10th Jan 2006, 08:17   #6
hitman012
What is a Dremel!?
Moderator
hitman012 has a spectacular aura abouthitman012 has a spectacular aura abouthitman012 has a spectacular aura about
I was also expecting this to be a £1k part, nice to see they've slotted it in near the existing FXs despite the obvious improvement. I guess it's cheap enough for them to produce, though.
I'd also like to know how far you managed to clock this . Did it come with any improvement on the 4800+ cooler?
__________________
"Nothing is more practical than a good theory"
- Kurt Lewin
hitman012 is offline   Reply With Quote
Old 10th Jan 2006, 08:58   #7
-EVRE-
Supermodder
-EVRE-'s Avatar
-EVRE- is on a distinguished road
Just curious. The Opteron 170 is a 1mb cash per core 2.0ghz socket 939 chip. I have never seen any word of the socket 939 Opterons in the Bit-Tech news. I am running one now and love it. at $368 I'd say its a better buy than a 3800+ @ $330 usd. Good review always good to see AMD squish intel
__________________
(Phenom II 940)(Foxcon A7DA)(8gb OCZ DDR2 800 )(8800gt aka hair dryer)(Big yellow case, CPU, GPU)(Enermax Liberty 500w)(lite-on DVD-RW w/LightScribe)(Seagate 300gb sata)(Seagate 320gb x2)(WD 200gb)(Dell 3007WFP 30"LCD, 19" Samsung, Acer 1280x720 projector)
-EVRE- is offline   Reply With Quote
Old 10th Jan 2006, 09:02   #8
Mister_Tad
Serious about coffee
Moderator
Mister_Tad's Avatar
Mister_Tad is just really niceMister_Tad is just really niceMister_Tad is just really niceMister_Tad is just really nice
Something i noticed a distinct lack of in the presler review as well
I'd be happy to pop it under water in the expert if you don't have the time Tim
Dual core opterons are pretty much impossible to get hold of in the UK at the moment unfortunately.
Mister_Tad is offline   Reply With Quote
Old 10th Jan 2006, 10:05   #9
apoogod
Xport1.com
apoogod's Avatar
apoogod is an unknown quantity at this point
What I want to know is, is it worth getting the FX-60 or get the 4800 or 4400?
__________________
It's like a koala bear crapped a rainbow in my brain!
apoogod is offline   Reply With Quote
Old 10th Jan 2006, 10:45   #10
Hamish
Hamish is on a distinguished road
The dual core processors are limited by the speed of our 16-speed LG DVD-ROM drive
why did you not just set dvdshrink to create an .iso instead of burn directly to dvd?
should be a pretty awesome chip if it clocks like previous FXs tho, my x2 is running at 2.6gig but it wont go much over that
Hamish is offline   Reply With Quote
Old 10th Jan 2006, 10:51   #11
Neoki
Hypermodder
Neoki's Avatar
Neoki is on a distinguished road
The 4400+ beats the fx60 in some of the tests. Go for that one instead as you can overclock to around 2.8 on air and is alot cheaper.
__________________
My Main Rig:|AMD 64 FX60 @ Stock|DFI LanParty SLI-DR | PC Power & Cooling 510 SLI EXTREME |2 GB Crucial Ballistix Tracer | 8800GTS | X-Fi Titanium Fatality®™ | Logitech® Z-5500 5.1|Hitachi 250GB x 3, 400GB, 160Gb, 120GB, SATA|Pioneer DVD-Rewriter Drive Black x 2 |
Neoki is offline   Reply With Quote
Old 10th Jan 2006, 10:58   #12
Hamish
what, no it doesnt
the 4400 is identical to the fx60 except its 400mhz slower and isnt unlocked..
mine seems to max out about 2.7gig too...
Old 10th Jan 2006, 11:05   #13
Nature
Supermodder
Nature's Avatar
Nature is on a distinguished road
A good read. I'm sure the AM2 model will be a wee bit faster...
But why did you use a 7800GT in your tests?
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs
Nature is offline   Reply With Quote
Old 10th Jan 2006, 11:05   #14
Shadowed_fury
Natural Born Chaos
Shadowed_fury's Avatar
Shadowed_fury is on a distinguished road
Now, thats fast!
__________________
Steam: kev_fury New Frag Video
- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston -
- Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA -
Shadowed_fury is online now   Reply With Quote
Old 10th Jan 2006, 13:59   #15
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
At CES I was discussing with another reviewer who said that with water cooling the chip has topped over 3.4, but that is an engineering sample.
Keep in mind, this has not been confirmed by Tim, who would probably throw something at me (and not the chip, sadly) for the suggestion that he should get to work now pushing max overclock. This review already took a bloody long time, and for good reason...lots of details, retests, etc. to make sure that you're getting fair and accurate marks with every chip on the same bios, drivers, etc.
If someone does go out and buy one to OC it, make sure you let us know how it performs!!!
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 10th Jan 2006, 14:36   #16
Pookeyhead
Pookeyhead's Avatar
As soon as I get home tonight, my FX57 goes on Ebay, then as soon as SCan get stock, I'll have one the next day, so I'll let you know.
__________________
Old 10th Jan 2006, 14:39   #17
specofdust
Banned
specofdust's Avatar
specofdust has a spectacular aura aboutspecofdust has a spectacular aura about
Wow, now thats public service!
If a moderately skilled overclocker has managed 3.4 on air I'd imagine over the next few months we can look forward to phase changed 4.0Ghz FX-60's....I'm practising the jaw drop
specofdust is offline   Reply With Quote
Old 10th Jan 2006, 15:02   #18
Marquee
Supermodder
Marquee's Avatar
Marquee is on a distinguished road
I personally have been waiting for a refined version of the AMD 64 X2 technology. Might just get into it now. But what I am thinking is that the overclocking must suck hard with these new X2 chips. The privies flagship was 2.8Ghz. Although we are getting now two cores at 2.6Ghz I was kinda hoping for at least 2.8Ghz or aim even higher 3.0Ghz. My other question you guys is it possible to take a low end X2 chip and overclock it to 2.6Ghz. Like the 4400+. Its clocked at 2.2Ghz with 1Mb cache for each core. I really wonder if I can clock that CPU at 2.6Ghz.
Nice CPU though.
__________________
Project Log: Knight Rider CWC
Marquee is offline   Reply With Quote
Old 10th Jan 2006, 15:09   #19
Shadowed_fury
Natural Born Chaos
Nice CPU though.
Clock rate is NOT everything.
__________________
Old 10th Jan 2006, 15:15   #20
specofdust
Banned
specofdust's Avatar
True, but we can't tweak the architecture of a CPU or add more cache by adding a new HSF
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
