Old 7th Feb 2006, 19:50   #1
Static Lullaby
Multimodder
Static Lullaby's Avatar
Static Lullaby has yet to learn the way of the Dremel
Koolance???
Koolance's ATI Waterblock Has anyone checked out any of the Koolance Hydra-Pak setups yet? Looks good as an idea, but not certain if it is really that much more helpful or even worth the cost. This is just one of their Hydra-Pak blocks I have seen out... they also have them for HD cooling.
Opinions?
__________________
ACS Case Build-off Contest
Static Lullaby is offline   Reply With Quote
Old 8th Feb 2006, 11:32   #2
Mankz
________
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Looks good, but probubly gonna cost quite a bit-
i would still go either for a Danger Den one, or a Fatal1ty hsf and ram sinks.
MAnkz
Mankz is offline   Reply With Quote
Old 9th Feb 2006, 01:50   #3
Techno-Dann
Disgruntled kumquat
Techno-Dann's Avatar
Techno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the Dremel
The hydra-pack cooler is only on the back of the video card. On the front, there's the usual ram and CPU blocks. If you've got a card with RAM on the back, or the Rage Theater chip, the hydra-pack system is great. Just make sure to leak test it before you put it on your card: Koolance had some trouble with quality control on their early ones.
As with most other Koolance gear, the hydra-pack cooler is designed for a low-flow, small-bore system. Don't expect to have one of them and a Swiftech Storm on the same loop and get decent performance from the Storm.
Techno-Dann is offline   Reply With Quote
Old 11th Feb 2006, 16:12   #4
Static Lullaby
Multimodder
Thanks for the input. I was curious mostly because of the clock on my ATI X800 Pro card right now... the GPU handles pretty well w/ the ATI Silencer that is on it now, but... the RAM still gets overly hot @ times... so I have to keep a few profiles in ATItool to keep it where it needs to be based on what I am doing.
I am familiar with other options, but really had not checked out the Koolance stuff much yet.
__________________
Reply
Tags
cooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
