#1 |
Just another nobody
Memory: is more always better?
#2 |
Richard Swinburne
bit-tech Staff
Command rate is the kicker, because everytime a command is issued, whether you have to wait a single clock or twice as long becomes more of an effect when you load the ram with plenty of I/O. If you have lower timings, then more commands can be issued which makes it more of a problem. Ive gotta say, using 1gig on this lappy is getting to be a problem now when I run half a dozen apps at once. 2gig on my main PC is a nice buffer, even though it is "slow" 533MHz 4-4-4-12-1T DDR2. 4 DIMMs on an Intel machine is fine ![]() I love the fact you've shown that 120MHz extra memory bandwidth and all you get is a single frame per second more. LOL. Although those games that really make use of large amounts of ram, like BF2 do show 5fps difference, but it is only 5fps and it' still maximum detail. I totally agree with your conclusion that getting another pair of 512s is more worth while, and possibly a bigger cooler (if you need it) to overclock a touch more to negate the few fps loss here or there.
__________________
#3 |
What is a Dremel!?
Moderator
A very informative and well-written article; this should help to cut down on some of the confusion in HW&OC about this subject (especially command rate) and certainly dispel a lot of myths about memory performance
There are a few typos: "assuming something about his breaks [brakes]" All the "prechange"s should be "precharge"s - result of automatic spell correction? "1T or 2T clocks" - should be "1 or 2 clocks?". I thought T was suffixed to the option in order to distinguish it as a time (I might well be wrong here, though).
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#4 | |
Pewlius Caesar
bit-tech Staff
__________________
#5 |
Supermodder
Well, i upgraded from 756MB (an odd number i know) to 2GB recently and i can't say i noticed any difference in gaming performance, i.e. frame rate. However, the overall computing experience was massively improved - minimum load times between levels in games, being able to alt/tab out of games to desktop in an instant, running itunes, photoshop, outlook, FF, messenger, DoD:S, etc. all at once with no performance hit. The single best upgrade i can remember having made. Such a pity it was horribly unstable and I've had to RMA it (Crucial Ballistix - anyone else had problems?), it's been 4 weeks now since i sent them back and i'm still waiting to here anything.
__________________
Athlon64 X2 4400+ || A8N SLI Premium || 2Gb Corsair XMS Pro || 2*40Gb Raptor (striped) || 250GB External || Radeon X1950Pro || WinXP www.OutForBlood.co.uk || www.4Qradio.com || www.EdwardChester.co.uk |
#6 |
Lazy Lurker
More RAM always = better unless your machine cant run it
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#7 |
Bwahahahahaha
The differences in frame rate seem minimal, but when playing games like FEAR, for instance, with a Gig of 3200 XL, I still get 'stalling' when running the game on the highest texture setting.
The frame rate is fine -- it's when you're walking down a corridor, you can tell when the scene ahead is being loaded, as the whole thing slows up as the pages are being transfered to the HDD. So there are other, more noticable reasons to go for more than 1GB of memory. |
#8 | |
Pewlius Caesar
bit-tech Staff
The only game that really makes a big difference in memory size is Battlefield 2 - you simply cannot run the game with all details set to maximum without hitching with only 1GB of memory.
__________________
#9 | |
Pewlius Caesar
bit-tech Staff
__________________
#10 |
Supermodder
well as far as gaming goes i wouldnt expect to see much of a difference concidering the card being used has a full 512 on it already. for people still using older systems with 128mb 6800s lets say, the upgrade from 2x512 to 2x1024 will DEFINETLY see a boost in gaming performance. people with 6800's still have a fairly competitive card that still cost within $250-400 or that they dont want to upgrade their motherboard too if they still have AGP. that is to say untill recently wotht eh 7800 GS (probly nto entirly worth the price of an upgrade) but i guarantee you will NOTICE an improvement . I have a 6800 with 256mb.... ill let you know how well the upgrade went once i get my new board, had to RMA a gigabyte... though i guess it woulnt be a direct comparrison concidering i had an AMD 2700+ before and now i have the opteron 148.... but anyway. untill next time kids
#11 |
mow?
Very well written and presented article. I found it to be incredibly useful. Shame there wasnt a few other brands offered just for fun but I can imagine the time invested for these 4 setups already. Thanks for another great article!
#12 |
Modder
Hey, one more thing, I've found that machines don't like it as much when you have chips of different size and timings, I think it has more to do with the timings.
Anyway, I've found that if you turn interleaving off [via the BIOS], it becomes <i>STABLE, but</i>... it becomes unbearably slow while gaming... anybody know why that is? |
#13 | ||||
What is a Dremel!?
Moderator
It improves performance, especially in memory-intensive applications where many reads and writes are being made to different areas of RAM - this is a situation typical of a computer game. I wouldn't have thought it would be unbearably slow, but it would definitely reduce performance. It's probably because the game's high amount of access to large strings etc. that would not fit in the L1/L2 caches mean that they're more RAM intensive. Edit: Quote:
__________________
"Nothing is more practical than a good theory" - Kurt Lewin Last edited by hitman012; 18th Feb 2006 at 15:54. |
#14 | ||
Multimodder
Not so. Memory management can become problematical with increased amounts of RAM-- Win 9x OS and associated apps only saw a performance boost in memory up to 1GB, after that the performance actually decreased because of management overhead (max allowable memory was 4GB, IIRC). I foresee a similar problem with XP; where that sweet spot will be is unknown, I'd hazard a guess that it would be around 4GB, but I have neither the time nor equipment to test that theory. Regardless, with the current state of gaming, memory increases above 2GB will not return any significant improvements, IMO. BTW, Quote:
__________________
If knowledge is power, then I know just enough to be Dngrs
#15 |
DUR HUR
Very good article, made the whole memory stuff a bit clearer to me.
After reading that I'm glad I didn't bother going for some expensive stuff and went with simple corsair value select. All I'm after really is real world performance. Maybe when I'm rich I'll go for the expensive stuff
#16 |
Mod Master
XP (not 64) can handle upto 4gig, however most motherboards can only address 3.8gig of ram(even if they say 4 gig)
also, XP can only address 2gig per thread so even if you have 4 gig(which i do) you can only use 2gig per thread thus its useless unless the program is multithreaded |
#17 | |
Supermodder
Asus a8n-SLI
__________________
(Phenom II 940)(Foxcon A7DA)(8gb OCZ DDR2 800 )(8800gt aka hair dryer)(Big yellow case, CPU, GPU)(Enermax Liberty 500w)(lite-on DVD-RW w/LightScribe)(Seagate 300gb sata)(Seagate 320gb x2)(WD 200gb)(Dell 3007WFP 30"LCD, 19" Samsung, Acer 1280x720 projector) |
#18 | |
What is a Dremel!?
Moderator
__________________
#19 |
When did I get a custom title!?!
I think 4gb setups will start coming in with vista, with it's memory hogging 3d interface. Running 1gb here and haven't yet run out of memory in any games, but my graphics card holds me back from the high settings. It's a big improvnment over 512mb though where I would have to wait for 2mins to get back into css after alt+tabbing out.
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#20 |
Minimodder
I don't understand why the slower 400Mhz XMS4000, but with lower timings, was beaten by the faster 520Mhz XMS4000, but with higher timings, in all four tests...
...I heard that you should always opt for lower timings over slight-higher speeds - isn't this true? And also, you didn't mention anything about which of the four memory formats you should look for if you intend to overclock... |
| Thread Tools | |
