Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 21st Feb 2006, 00:19   #1
DXR_13KE
BananaModder
DXR_13KE's Avatar
DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.
screen goes green with .wmv files
when i play a wmv file on any media player sometimes it works ok but most of the times the program sort of blocks and the screen of the player goes totaly green.
does this happen to anyone else? does anyone know the solution?
__________________
Renegade X - Release Date Unveiled
Check it out!!
DXR_13KE is online now   Reply With Quote
Old 21st Feb 2006, 10:57   #2
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Bad graphics or chipset drivers or a bad file or a bad WMP install.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 21st Feb 2006, 14:32   #3
DXR_13KE
BananaModder
DXR_13KE's Avatar
all other video tipes work great. and the screen goes greeen even in VLC and irfan view
__________________
Check it out!!
Old 21st Feb 2006, 14:51   #4
CarlT2001
Supermodder
CarlT2001's Avatar
CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.CarlT2001 is a hoopy frood who really knows where their towel is.
I would - uninstall any codecs you may have installed, uninstall graphics driver, reboot, reinstall graphics driver, reboot, reinstall codecs.
CarlT2001 is offline   Reply With Quote
Old 21st Feb 2006, 17:23   #5
DXR_13KE
BananaModder
DXR_13KE's Avatar
ok, will do that and post the result
__________________
Check it out!!
Old 21st Feb 2006, 17:53   #6
Malvolio
Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.Malvolio is the Cheesecake. Relix smiles down upon them.
I'm 100% sure you've got a bad WM9 codec Go here. Download it, use it to uninstall your current codec (if it detects that it's installed), then reinstall it.
Malvolio is offline   Reply With Quote
Old 22nd Feb 2006, 16:54   #7
DXR_13KE
BananaModder
DXR_13KE's Avatar
works like a charm now, thanks all!!!
__________________
Check it out!!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
