Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 24th Feb 2006, 22:21   #1
SiH
Minimodder
SiH has yet to learn the way of the Dremel
Converting M3U to MP3?
Hi,
I would so grateful if someone could tell me how to convert M3U files to MP3.
I am unable to find a single utility on the web for this.
Many thanks in advance.
Si... [from the UK]
SiH is offline   Reply With Quote
Old 24th Feb 2006, 22:39   #2
ajiKaBooM!
Supermodder
ajiKaBooM!'s Avatar
ajiKaBooM! has yet to learn the way of the Dremel
aren't m3u a playlist file?
ajiKaBooM! is offline   Reply With Quote
Old 25th Feb 2006, 00:16   #3
yodasarmpit
No longer the other Brett.
yodasarmpit's Avatar
yodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyan
The m3u file doesn't contain any data, it's just a playlist, it points to mp3 files.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
yodasarmpit is offline   Reply With Quote
Old 25th Feb 2006, 00:22   #4
ajack
rox
ajack's Avatar
ajack has yet to learn the way of the Dremel
Surely you must have realised this when the M3U file is like a couple of K in size...
__________________
ajack.org
DA | Flickr
select * from pants;
ajack is offline   Reply With Quote
Old 25th Feb 2006, 01:01   #5
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
There really isn't a way to "convert" an M3U file into an MP3 as the M3U is just a link.
If you still have access to the M3U file, you can still use it to find and save the MP3 it links to. To do so, right-click on the link that opens the M3U and tell the computer to "Save Target As" onto the desktop.
When the M3U is finished saving, open up NotePad or WordPad and drag the file M3U file onto it (this will open it). Inside of the M3U file, you will find the link to the MP3 that it was meant to stream.
Just highlight and copy this URL and then paste it into your browser's address bar. That should take you to the MP3 that you were looking for.
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 25th Feb 2006, 01:06   #6
ozstrike
yip yip yip yip
ozstrike has yet to learn the way of the Dremelozstrike has yet to learn the way of the Dremel
That is a neat trick. Never thought of doing that.
__________________
Last.FM | Flickr | Enter the POTM! | Blog
ozstrike is offline   Reply With Quote
Old 20th Mar 2008, 21:07   #7
gglynnd
What's a Dremel?
gglynnd has yet to learn the way of the Dremel
All is not lost, you can still get your music into an mp3 file. Capture the music file with a program called "Audacity", then export the file as an mp3, wav or ogg. Then use another program called "Switch" to convert it further to a CDA, for instance.
gglynnd is offline   Reply With Quote
Old 20th Mar 2008, 21:41   #8
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
Actually M3U can be a streaming MP3 file, rather then a playlist, it's used a lot for radio-webcasts.
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 20th Mar 2008, 22:07   #9
Squadexodus
I got my cookie. What about you?
Squadexodus's Avatar
Squadexodus has yet to learn the way of the Dremel
Could he be wanting to know because the mp3s were deleted? just a thought...
__________________
I blame the sun. It makes my computer short out.
http://valid.x86-secret.com/cache/banner/357403.png
Squadexodus is offline   Reply With Quote
Old 18th Sep 2008, 15:52   #10
48yroldfemale
What's a Dremel?
48yroldfemale has yet to learn the way of the Dremel
convert m3u to mp3
Hi there SiH,
Converting m3u files to mp3 files CAN be done - I am very proud of myself. Having never done anything like that before (actually until tonight I hadn't even [I]seen[I] an m3u file extension name, I googled and found this site http://en.kioskea.net/faq/sujet-339-...3u-to-mp3-file I then downloaded the program and converted the files and put them in My Music file. Being a 48 yr old female (as my user name implies), I thought I was quite clever! This kind of 'thing' is not usually up my alley so as my original 'google' had found your question, thought it only right that I should find 'you' again and reply. Good luck.
48yroldfemale is offline   Reply With Quote
Old 18th Sep 2008, 16:01   #11
djDEATH
Habari gani?
djDEATH's Avatar
djDEATH has yet to learn the way of the Dremel
no its not, its a playlist that points your web stream to where the real mp3 is at, as per the notes inserted above by cpemma
__________________
BEASTIE-II Asus N550LF CK-108H Core i7, GT745M B&O Speakers
djDEATH is offline   Reply With Quote
Old 1st Mar 2011, 17:19   #12
klh0320
What's a Dremel?
klh0320 has yet to learn the way of the Dremel
M3U's to MP3
It is simple to do this... much simpler than I figured it to be!!!
Just save the list to your desktop for easy access in the M3U format.
Then open your Windows Media Player. Choose File, Open, desktop, and the file then as it is playing, you can then sync the Now playing files to your MP3 player device.
Or whatever your next step is.
I hope this helps!
klh0320 is offline   Reply With Quote
Old 14th May 2012, 13:37   #13
CarlaEllis
What's a Dremel?
CarlaEllis has yet to learn the way of the Dremel
The same file can be imported repeatedly, but its output formats can be different. Thus, users can receive a series of different audio files even thought they have only one source file.
flac to mp3 software
CarlaEllis is offline   Reply With Quote
Reply
Tags
windows
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
