#1 |
Just another nobody
The Core of Intel's new chips
#2 |
Natural Born Chaos
Thats quite clever tbh..
__________________
Steam: kev_fury New Frag Video- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston - - Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA - |
#3 |
Slacking off since 1986..
Good read, some of it went over my head but interesting all the same.
#4 |
Group 7 error
NOTE: read in the afternoon and NOT the evening.
But apart from that, very informative.
__________________
http://www.ctrlaltdel-online.com 100% Brainless] |
#5 |
Minimodder
Excellent job explaining things.
#6 |
What's a Relix?
sounds like they got some killer performance enhancements and some really great power management stuff coming up in the next batch. I can't wait to buy a new computer with one of these beasts. So do these processors classify as 64-bit like the Athlon 64's or are they now 128 bit, meaning even more performance than the athlons?
__________________
Sam0r: Mr. Winky got a little aroused, needless to say I was tenting. Women... know your place. |
| thecrownles |
| View Public Profile |
| Find More Posts by thecrownles |
#7 | |
What is a Dremel!?
Moderator
Nice article
Just one bit that isn't quite right as far as I know: Quote:
The disadvantage of a long pipeline - specifically, one as large as Prescott's - is that it hugely increases penalties for various inherent problems with the processor. Branch mispredicts, although rare, mean that the CPU has to actually flush the entire pipeline of instructions and load the correct branch again - the minimum P4 mispredict penalty is over 20 clock cycles for data in the L1 cache. Pipeline bubbles, where the processor can't schedule two instructions to be executing simultaneously (or close to one another), result in a further loss because the bubble (i.e. an empty pipeline stage) propagates all the way down the chain. I imagine that the huge amount of work that the Willamette team did with the scheduling unit to stop this happening has moved right into Conroe. As far as I know, instructions can't go down the pipeline without being completed - however, the above flush means that some must be removed before they can finish and others put in their place. I hope this doesn't sound like I'm criticising the article, because it does a very good job of explaining the architecture
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#8 | |
Richard Swinburne
bit-tech Staff
#9 |
Hypermodder
Great article!
#10 | |
Just another nobody
#11 |
Richard Swinburne
bit-tech Staff
Basically if you get a pipeline stall, for whatever reason, it has to flush part/all of it and start again. Long pipeline = massive performance hit. Longer pipeline = lower IPC but higher mhz because netburst was all about sheduling and keeping a large flow of data ready from high speed, long latency devises like RDRAM.
#12 | ||
What is a Dremel!?
Moderator
.Quote:
__________________
#13 |
Lazy Lurker
It stops the information from cycling through the processor again and again and again ultimately; netburst is all about rapidly chewing through the data it gets all at once, storing the important stuff, figuring out what needs to be done, and putting it through quickly, quickly, quickly; we just dont live in that type of a processing world.
/me wibbles himtan012 and his gift for extensive, in depth architecture talks
__________________
Technology Schmecnology |
| RotoSequence |
| Find More Posts by RotoSequence |
#14 |
Hasselhoff™ Inside
this should be interesting when it comes out i can't wait to see some perfromance figures....the way i like to see this is so;say the P4 precotts for example were like american cars they have BIG V8 engines (long pipelines) that chew through huge amounts of fuel (data) but still manage to produce not very much horsepower or torque (IPC) but you can strap on superchargers and such like (highier clock speeds etc..) to get a bit more power out of them...whereas on the other hand the Core architecture will be more like a European car it will have a sensibly sized engine (14 stage pipline the ballence for both long and short instructions) will use a sensible amount of fuel (in this case power) but still manage to jump up and down all over the V8 and produce more power and torque (IPC) then you can dd little bits here and there like an ECU re-map (the prefecther tweaks etc..) to give you more power.
i know its a bit of a strange way to look at it but it does make it nice and understandable i think |
#15 |
Supermodder
Well, the big question now is do AMD have an answer to Core? Or are they relying on there current lineup to compete for a while yet?
__________________
Athlon64 X2 4400+ || A8N SLI Premium || 2Gb Corsair XMS Pro || 2*40Gb Raptor (striped) || 250GB External || Radeon X1950Pro || WinXP www.OutForBlood.co.uk || www.4Qradio.com || www.EdwardChester.co.uk |
#16 | |
Modder
__________________
Asus P4P800 SE|P4 3.0E @ 3.6ghz |Utra 1536 mb PC3200 dual channel|Maxtor 80gb| Maxtor 120gb|Saphire X800 pro vivo-> xt pe @550/560|Artic Cooling V4|Thermalright xp-120|Lian Li pc-6077 |
#17 |
Minimodder
can you show us these PowePoint documents or whatever else you read for this article?
I bet it would be interesting to see more pro-orientated form of this! / i can't belive i'm going to study this kind of **it after a year ...no really...286's way of working(which makes you understand all processors way of working) is in the program of my technical desciplines in 12th grade/Is it true that Pentium M's microarchitecture is "closer" in design to Pentium 3's than it is to Pentium 4's?/one of the reasons its better than P4/ |
#18 | |
What is a Dremel!?
Moderator
__________________
| Thread Tools | |
