Graphics 7900GT Overclocking Help Please - Off the scale
Discussion in 'Hardware' started by M@tt, 11 Mar 2006.
  1. M@tt
    M@tt What's a Dremel?
    12 Feb 2003
    Hello Guys, I wonder if anyone can help please :)
    I have installed CoolBits Reg, but have reached the end of the scale in Memory overclocking without any errors at all in 3Dmark 2005, so I would like to up the memory some more to find the limits.
    How do I increase the mem scale please?
  2. chemo
    chemo True Jungle Brother
    20 Feb 2005
    have you tried using riva tuner? that might give you more of a limit mate
  3. M@tt
    12 Feb 2003
    Riva tuner does not seem to offer any overclocking options, I don't think it knows what it is.
    Thanks for the idea though :)
  4. chemo
    20 Feb 2005
    ooo, what about ati tool? that might do it.
  5. M@tt
    12 Feb 2003
    Will that work with Nvidia?
  6. chemo
    20 Feb 2005
    so ive heard yeah. only use it for clocks though, dont take any notice or change anything else like temps or fan speeds etc. although the artifact box is still worthy
    worth a shot mate but let us know for sure if it does help :)
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Use Rivatuner :) There's an option to increase the clock limits
    If you goto the advanced users part, then the "overclocking: global" option there should be a setting in there :)
    Maxing the sliders is awsome, go for the GPU too ;)
  8. M@tt
    12 Feb 2003
    I'm still stuck, I have had a good fiddle with RT but I'm still at 822 limit :)
    The core will not go up much more than that with the default cooler at least.
  9. Highland3r
    25 Jul 2003
    The sliders still only go to 822?
  10. M@tt
    12 Feb 2003
    Yes I know it says 10,000 in the picture, but I tried 1000 and 999, I'm lost really :)
    I'm still playing though.
  11. M@tt
    12 Feb 2003
    Does anyone know which program this guy is using, I have used that program before, but I cannot for the life of me remember what it is :)
    EDIT Sorted now PowerStrip did it / does it :)
  12. kenco_uk
    28 Nov 2003
    You quite literally have to let us all know how far you push your gfx card. It's the law :)
  13. Max Tractor
    Max Tractor Minimodder
    15 Jan 2006
    Yes power strip will sort it, I actually prefer it over the rest anyway, but is there not a coolbits reg tweak to go beyond what it can do just now?
  14. nigely
    nigely What's a Dremel?
    3 Nov 2005
    how about flashing it to 800 for ram, and maybe it will let you go higher with the silder?
