Old 14th Mar 2006, 21:49   #1
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.The_Pope is definitely a rep cheat.
Arctic Cooling Silentium T1
http://www.bit-tech.net/modding/2006...tium_t1/1.html
The_Pope is offline   Reply With Quote
Old 14th Mar 2006, 22:07   #2
kempez
modding again!
kempez's Avatar
kempez has yet to learn the way of the Dremel
Certainly interesting. I think if they put a couple of fan grills and a bit bigger PSU that would be an excellent solution
__________________
I don't like streets of rage - make fun of me!
27" iMac, iPhone, AppleTV, XP Laptop, xbox 360, PS3, VirginTV/BB and a whole load of decent home audio.
Old projects: Project [/B]<<| Black3d |>> Project[Aqua Vitae
kempez is offline   Reply With Quote
Old 14th Mar 2006, 22:13   #3
ozstrike
yip yip yip yip
ozstrike has yet to learn the way of the Dremelozstrike has yet to learn the way of the Dremel
Looks pretty good, too.
The retention bracket for the PCI cards, isn't that similar to the Mesh reviewed the other week? (it dodn't get a very good review then).
__________________
Last.FM | Flickr | Enter the POTM! | Blog
ozstrike is offline   Reply With Quote
Old 14th Mar 2006, 22:16   #4
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming Saiyan
I not to found on the idea of haveing the HD and the PSU right beside each other. But the dual fans at the top look nice. I like the way they mount ther fans.
Marquee is offline   Reply With Quote
Old 14th Mar 2006, 22:22   #5
BioSniper
I Mod, Therefore I Own
BioSniper's Avatar
BioSniper has yet to learn the way of the DremelBioSniper has yet to learn the way of the DremelBioSniper has yet to learn the way of the DremelBioSniper has yet to learn the way of the Dremel
I was looking at these a wee while back and its nice to have someone satisfy the questions I was thinking of. Shame the PSU isnt really replaceable though as it looks like a nice case.
It also appears to lack provisions for multiple hard drives being silenced or is it just me?
BioSniper is offline   Reply With Quote
Old 14th Mar 2006, 22:42   #6
JCBeastie
Supermodder
JCBeastie's Avatar
JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.
Personally I thought it looked shockingly bad!
80mm fan mounts are completely obscelete these days, added out of sheer lazyness on AC's part. Granted Ac's fans are very high quality and silent, but still...
Another thing I couldnt beleive is that It doesn't allow you to use a third-party PSU either!! 350watt is NOT suffecient these days!
Not to mention the lack of space and mounts for HDD's, I expected a lot more from Arctic Cooling.
JCBeastie
JCBeastie is offline   Reply With Quote
Old 14th Mar 2006, 22:56   #7
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 has yet to learn the way of the Dremel
I think it's a good case apart from the flaws pointed out. The 80mm fans are very good I have one on my cpu and it pushes alot of air for its noise level. If the case had a 120mm fan artic cooling would have to make one themselves or buy one in and it would require the case to be taller.
It does need modding to acomodate a gaming system though.
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 14th Mar 2006, 23:47   #8
ralph.pickering
Supermodder
ralph.pickering has yet to learn the way of the Dremel
Compared to several hundred pounds for the Zalman TNN series of cases I guess it's not a bad deal, even if you are limited to lower powered graphics cards and processors. I know quite a few people who would trade off upgradeability for a silent machine. Personally I find the styling not quite to my taste... one step away from a beige box really.
ralph.pickering is offline   Reply With Quote
Old 15th Mar 2006, 03:25   #9
customh
conflagration.
customh's Avatar
customh has yet to learn the way of the Dremel
Looks pretty nice and for the average gram and gramps/ mom and pops application of email and internet a mid range system would be just fine, especially if its quiet, you learn these things when you leave the stock fans in you moms centurion c5 it is a bit loud.
customh is offline   Reply With Quote
Old 15th Mar 2006, 03:44   #10
speedfreek
Ultramodder
speedfreek's Avatar
speedfreek has yet to learn the way of the Dremel
Exactly what I was thinking, it would be a perfect oem replacement.
__________________
Q6600 | HD5870xxxUBERversion | 6gb of RAM | Several TBs of hdd
now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem.
Laptop: HP EliteBook, its fast!
speedfreek is offline   Reply With Quote
Old 15th Mar 2006, 11:31   #11
parag0n
Minimodder
parag0n has yet to learn the way of the Dremel
I love the fact your "office PC" is pretty much 3x as powerful as my gaming PC :/
Still, NICE case, not so pretty IMO, but those fans look super quiet! Will they be available seperately for those of us with excessively loud PCs?
parag0n is offline   Reply With Quote
Old 15th Mar 2006, 12:10   #12
LukR
Minimodder
LukR has yet to learn the way of the Dremel
If you use a decent PSU with strong enough 12V rails, 350W is more than enough for a single core intel or a dual core amd and 1 VGA.
Seasonic manufactures good PSUs, not some labeled for 500W POS not capable of delivering more than 200W contiuous.
FIY: a pretty expensive 550W PSU failed to give more than 250W power on the 12V rail, but the much less expensive 400W FSP Green Power easily put out more than 320W on the 12V rail, with much better effeciency and voltage regulation.
BTW this case is a few years old...
"Arctic Cooling's Silentium T1
by Cheese on 17th November 2004" << already posted here
edit: spelling
LukR is offline   Reply With Quote
Old 15th Mar 2006, 12:41   #13
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox has yet to learn the way of the Dremel
Yeah you started actually shown the PC builds again. I thought you had resorted to showing pictures provided by the manufacturers and doing theoretical analysis.
I'm not too fond of this case.
HDD attached to the PSU....eh not for me thanks!
Cable management looks like a farce in that thing as well! Looks way to plastic too!
Good review though!
zr_ox is offline   Reply With Quote
Old 15th Mar 2006, 15:17   #14
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
This one. They aren't the same, but the principle is similar. I just had a quick play with the Mesh version and I can say the Arctic Cooling design is vastly superior.
I agree with Wil that the Mesh mechanism is difficult - thumbscrews *would* be better though given that buy the system pre-built, it's less of an issue really. Since the Silentium T1 is aimed at the self-build crowd, the expansion card retension mechanism is more important. Luckily, at least in my opinion, AC nailed it.
Old 15th Mar 2006, 15:21   #15
Godboy_g
Supermodder
Godboy_g's Avatar
Godboy_g has yet to learn the way of the Dremel
Looking at the pictures, you should be able to disassemble the PSU, and replace the guts with your own chosen psu.
Unless the one they are using is smaller than a standard sized one.
__________________
I AM Backwards compatible!
Godboy_g is offline   Reply With Quote
Old 15th Mar 2006, 19:06   #16
darklord
Minimodder
darklord has yet to learn the way of the Dremel
Arctic do a newer T2 version which is costs about 60 and has a 430 watt power supply which might be better but I would like to see a review of this newer case rather than a case that is two years old! but they have kept the same sort of principles as in the T1 though so should be similar in terms of silence.
darklord is offline   Reply With Quote
Old 15th Mar 2006, 23:56   #17
Munterofamodder
Multimodder
Munterofamodder's Avatar
Munterofamodder has yet to learn the way of the Dremel
I got a T2 from Overclockers about 8 months ago, its not a bad case at all. The power supply does seem quite good and the 8cm fans are cool, and very very quiet. It's totally negated by the northbridge fan on my motherboard, but that will be going shortly...
A decent 350w psu is certainly enough for most people's computers, bar those using the highest end cpus, overclockers and dual-gpu users. Its so much more important what the quality of the psu is than what it says the peak wattage is on the label!
__________________
Make fruit hats for pets.
Munterofamodder is offline   Reply With Quote
Old 18th Mar 2006, 08:01   #18
JrRRr
Minecraft addict
JrRRr's Avatar
JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.JrRRr is the Cheesecake. Relix smiles down upon them.
Couldn't agree more!
Nice review, thanx!
I think it's an interesting case, espesially if you think of all the folks who just needs a quiet, (relatively) small case that houses just the things you need to do some office/internet-work and play a game once in a while.. ..it should have plenty to go around..
__________________
So yeah, my english is not the best. In other words; please be patient with my grammar and other non standard way of writing things..
JrRRr76 on Minecraft..
JrRRr_nor on Steam
JrRRr is offline   Reply With Quote
Old 22nd Mar 2006, 16:16   #19
TMM
Modder
TMM's Avatar
TMM has yet to learn the way of the Dremel
I seriously doubt the capabilities of the PSU considering Antecs cheapest PSU (SP2 350W) can power a system that pulls about the same power as P4EE + 7900:
http://www.overclockers.com.au/article.php?id=455012
__________________
no, your face.
TMM is offline   Reply With Quote
Old 23rd Mar 2006, 00:15   #20
webbyman
Hax.
webbyman's Avatar
webbyman has yet to learn the way of the Dremel
blah, i wouldn't looks like your a bit of an Antec fanboy
im sure the psu in there would match one of antecs of an similar rating
webbyman is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
