Thread Tools |
#1 |
Geoff Richards
Moderator
Alphacool Watercooling Starter Kit
#2 |
Evilish Monkey ++;
Great article
[The 'buy it here' link on the last page is also broken]
__________________
|eBay| Because monkeys never hurt anyone. |Hexus|
-=|For Sale Thread|=- -------- -=|My Site|=- "If crime fighters fight crime, and fire fighters fight fire, what do freedom fighters fight?" [atrack]monkeyville[/atrack] |
#3 |
inter arma silent leges
Moderator
external link fixed.
__________________
"Flying is simple; push on the stick and the houses become bigger, pull back on the stick and houses become smaller, unless you keep pulling in which case the houses will become bigger again..." Disce quasi semper victurus; vive quasi cras moriturus. |
#4 |
True Jungle Brother
nice review there, its filled in a few holes i had about WC'ing. im thinking about a kit like this and it certainly looks better than the coolermaster kit thing
__________________
Don't hate the Geek, Hate the code!
#5 | |||
____
The insufficient coolant seems like a big mistake - perhaps it should be diluted? I got scared by the last line: Quote:
__________________
Have you seen The SketchUp Components Collection's latest items?
Interested in a DXF Blueprints Collection? Discuss it here. Last edited by The_Pope; 29th Mar 2006 at 15:11. |
#6 |
Hypermodder
I'd imagine it can be diluted though I wonder how much pipework you have used, I bought an alphacool kit, a ready2go one ( pretty much same stuff but preinstalled in a CM Stacker with 3x120mm rad in top, prefilled, £235 specialtech ), even better for beginners as its prefilled and you just have to put all your stuff in the new case and switch it on, although I didn't do that I drained it, added two gpu coolers to it plus some mosfet coolers and filled it with the same 500mm Alphacool bottle, it may be that your resevior is larger, mine is square and looks smaller.
Anyway seems like a good bit of kit
__________________
Into Gaming and around Bristol, UK, Click Here Last edited by sandys; 29th Mar 2006 at 15:25. |
#7 |
Supermodder
Nice review, still don't have the guts to stuff water into my computer tho
I was however very impressed with the new Zalman heatsink!!
__________________
If it isn’t broken, fix it. If it is broken, mod it till it looks like it's meant to be broken. |
| Dr. Strangelove |
| View Public Profile |
| Find More Posts by Dr. Strangelove |
#8 |
Multimodder
Hmm, I'd love to watercool, but the thing holding me back is my socket A motherboard without mounting holes. It seems that hardly anyone makes a bracket that mounts to the socket tabs. It looks like this kit might use the tabs for a socket A. Would the BT staff be willing to verify that?
__________________
New and improved Jibberish! Now with 20% less coherency! Mods & Creations: Black Energy, AL-rylik |
#9 | |
Ultramodder
| unrealhippie |
| Find More Posts by unrealhippie |
#10 |
Ultramodder
The copper heatsink did pretty well considering the load. I wonder how much overclocking even more would have shown?
__________________
Top 5 Listening to Now - A Second To Last - Dying Against Your Will Rock Kills Kid - Paralyzed Zero State Reflex - I'm Splintering Hot Hot Heat - Middle of No Where ![]() - www.nerges.net |
#11 |
yip yip yip yip
Good review. It's great how companies are trying to get more people into WC. I'd love to try it, but I don't have enough money.
![]() It would have been nice to see how well it performs when pitched against a proper, custom built WC setup, just to see how close you can get to it for the money. |
#12 |
Bling!!
How much liquid did you need in the end. I have a similar loop with an extra 3 blocks but an Aquatube in place of the submerged pump and it's completey filled with around 300ml.
I like Alphacool kit recently. It's very good value for very good performance. |
#13 |
Ultramodder
It looks good for someone just starting out but if I would go to water I would want to do everything, CPU, GPU, northbridge. And the manual issue wouldnt bother me much, hardly read the things anyway unless somthings missing.
__________________
New Rig, Quad Core and 8800 baby! now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem. New Laptop: HP EliteBook, its fast! |
| speedfreek |
| Find More Posts by speedfreek |
#14 |
Mod Master
Minor point is that the you can still install it if you don't have a PCI slot free as it isn't actually using PCI, you just need somehere to stick that PCB
Major point is that it can be upgraded and expanded with part form a big range of suppliers - this doesn't tie you into one range of parts.
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules. |
#15 | ||
Moderator
I'll answer all other questions tomorrow when I have another play with it.
__________________
#16 |
SMEGHEADS!
Don't be afraid of leaks, my watercooling setup has leaked twice, both times all over the graphics card (1st time a 9700np, 2nd time a 6800le), because I didn't seal the thread on the barbs on my TDX. Both times I dried it out and everything worked fine afterwards. The Irony is that I sealed everything else and assumed the waterblock would be ok
. My system seems to take around a litre, possibly a little more. eheim 1250, TDX, BIX120.1, and several feet of 1/2" ID tubing.
#17 |
Modder
Nice review. Good starting kit
Have also a nice kit laying around only the bloks fore gpu and NB leak because the screws are over tightend. So almost fineshed with building new cover out of aluminium so within some time I will install it in a Antec Sonata. But also thinking of buying a lianl li case. just a simple one with enough room. |
| The Bart Man |
| Find More Posts by The Bart Man |
| Thread Tools | |
