Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 31st Mar 2006, 13:19   #1
hylian_231
What's a Dremel?
hylian_231 has yet to learn the way of the Dremel
Network problem
I am currently at a LAN and we've got a problem with my computer, I can connect to the internet, but I can't use msn messenger, when I click to troublshoot it says that theres a problem with the keyports.
I can view the other computers shared files, but they cannot view mine, I can't see their games when they host. I can use any other program that uses the internet, eg. limewire, gamespy arcade
Please help, this is bugging the hell out of me...
hylian_231 is offline   Reply With Quote
Old 31st Mar 2006, 14:15   #2
wharrad
Hypermodder
wharrad's Avatar
wharrad has yet to learn the way of the Dremel
I know it's basic, but try disabling XP firewall or/and any other firewall you have. One way connection problems tend to be based in firewalls.
__________________
Jimmy Carr - "It's easier to get forgiveness than permission"
wharrad is offline   Reply With Quote
Old 31st Mar 2006, 15:48   #3
hylian_231
What's a Dremel?
There aren't any firewall programs running or any antivirus programs running, the windows firewall has been disabled. I'm using his mum's computer and it wors perfectly as soon as we plugged it in. It's something with my computer obviously
Old 31st Mar 2006, 16:02   #4
LAGMonkey
Group 7 error
LAGMonkey's Avatar
LAGMonkey has yet to learn the way of the Dremel
it could be to do with the port settings. Does the modem/router that your connecting have UPnP?
MSN messenger needs seperate ports to run so that it dosent get confused. If the modem hasnt got UPnP your version of Messenger will try to connect on the same ports used by your friend and it wont work.
__________________
---------------LAG out!---------------
http://www.xkcd.com
100% Brainless]
LAGMonkey is offline   Reply With Quote
Old 1st Apr 2006, 03:39   #5
Buzzons
Mod Master
Buzzons has yet to learn the way of the DremelBuzzons has yet to learn the way of the Dremel
random thing : check the system time and date is correct -- if its wrong MSN dies
Buzzons is offline   Reply With Quote
Reply
Tags
network
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
