#1 |
Hater of Seagate
Overheating issue.
I've recently put together a PC.
The specs are: Pentium 4 2.8ghz Prescott Zalman Flower heatsink + 120mm fan MSI 848P Neo-V Mainboard 512mb DDR Ram (Micron Technology Cas 3 at 200mhz) Geforce 4 Ti4200 64mb 120gb Maxtor Diamondmax +9 SATA Hdd Now, at idle, my cpu is at 75ēc and hits 89ēc when playing Counter-Strike: Source, the system doesn't crash, but hl2.exe unexpectidly quits. There is obviously a problem here, the 120mm fan is runnig at 7v as are the two fans next to the CPU. There is also an 80mm fan blowing in from the front. Any ideas? The CPU voltage is at default.
__________________
Lenovo 3000 N200 - C2D 1.6 - 2gb DDR533 - 120gb HD Xbox Live Gamertag: Sam00r | My Blog Type Thing
#2 |
Tyrannosaurus Alan !
F*** me! Just a little hot, try reseating the cooler with some AS5. also if you touch the HS (for more than 5s) is it really hot ? It could just be a sensor error...
__________________
{Macbook Pro + Dell 2407 WFP - Canon 3000V + Canon 350D + BG-E3 + Sigma 10-20mm + 50mm f1.8 + kit 28-90mm EF - Rolleiflex 2.8 TLR}
*Flickr ~Flickriver ^ My Behance Art Folio |
#3 |
Hater of Seagate
Yeah, I've touched the heatsink, and it didn't feel that hot at all. My G4 runs at 57c and touching the heatsink on that hurts.
Its only just been put together though, less than a week. I didn't even know it was overheating untill last night, when I installed MBM5 and saw the temperatures! Although, if I turn the fans to 12v, everything goes down to around 55c, but its very, very noisey. But, with a 120mm fan on it, it shouldn't need to be running at full wack, should it?
__________________
#4 |
I Mod, Therefore I Own
I seem to remember something about MSI being pretty bad at temp reporting.
Otherwise, like fr4nk said, a reseat is the best idea.
__________________
Steam: kev_fury http://www.youtube.com/user/furyksx - DFI x58 t3eh6 - i7-920 - XFX 6870 1GB - 6GB Patriot - - AstroGaming a40s - SteelSeries 7G - Razer Deathadder - 2209WA - |
#5 |
Super Moderator
Moderator
Reseat the sink. I doubt it's a temp probe problem, they're usually out by a few degrees, but not by 30+.
Wasn't there a little app somewhere that told you if P4's were doing the thermal throttling thing? If you found that you'd know what was going on instantly. |
#6 |
Omnipwntent
That's LGA, right??
You've not got the contact right. LGA is a sheer absoulte ******* to get right. There's no in between you either nail it with a perfect contact and get 40C or get nearly nuclear. That's why I went for this: ![]() My theory is that people just dont make good contact, because since using this Ive never had problems with Prescott temps, even my dual core.
__________________
Slash88: That kettle video just made me go death thanks. Fizzban: And it is being panda'd to..lame. |
#7 |
Hater of Seagate
Its S478 Bindi
![]() I'll have a look into the throttling thing, thanks krikkit Edit: How ironic, as soon as I'd posted that, the fire alarms went off
__________________
#8 |
Lazy Lurker
Heheh, ironic indeed. Sounds definitely like a seating issue; my friend's Pentium D was running at 80° Celsius the other day; turns out the heatsink was completely blocked with dust. (Dumb ignorant users and a PITA uber prideful paren t not letting people of non vietnamese descent look at it
__________________
Technology Schmecnology |
#9 |
I just noticed that you have a MSI mobo and that I remember you overclocking this chip, though it's a long shot, when I had my X2 on my old MSI mobo after a few months of having it OCed the temp sensors went mad, it reported temps of 125C & -50C. maybe the same thing could be happening with you...
__________________
#10 |
Hater of Seagate
Hmmm very possible fr4nk, although now I'm running it at stock.
Doesn't explain why it goes down to 55c when I turn the fans up to full though.
__________________
#11 | |
Super Moderator
Moderator
If you think that this is caused by sensor miscalibration, it might be worth checking MSI's site for any updates to the BIOS with fixes listed in the notes. I'd definitely reseat that heatsink, though
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#12 |
Hater of Seagate
Ok, I've re-seated the heatsink, same problems.
Also, I'm running the latest bios. Hmm
__________________
#13 |
Super Moderator
Moderator
Did you clean off the existing thermal paste and apply a fresh application?
__________________
"Nothing is more practical than a good theory" - Kurt Lewin Last edited by hitman012; 5th Apr 2006 at 19:32. |
#15 | |
Hater of Seagate
I'll give that app a go now.
__________________
#16 |
There is no rep for awesomeness.
Moderator
Are the temps as reported by BIOS or by MBM? MBM can throw up extrememly weird results if not set up correctly for your mobo (anything from -50 to +127C).
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#17 |
Hater of Seagate
Both BIOS and MBM5. Also, its not throttling at all, what temp do prescotts throttle at?
__________________
#18 | |
Super Moderator
Moderator
[edit] After reading up, it doesn't generally throttle properly until about 85+, so did you test it idle or under load? [/edit] Last edited by Krikkit; 7th Apr 2006 at 10:00. |
#19 |
Hater of Seagate
Well, under load as I played linage 2 for a few hours to get it going. Came back from lineage 2 and it was at 90degC.
The program didn't report any throttling. I think I'm just going to leave it, its deffinately reporting the wrong temperature, if it WAS at 90degC, I'm very sure something would've gone pop or at least the game would've crashed.
__________________
#20 |
Super Moderator
Moderator
Perhaps, perhaps not, that article seems to say that you don't really see a performance diff. right up until it throttles...
| Thread Tools | |
