Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 6th Apr 2006, 02:50   #1
mattthegamer463
Mod Master
mattthegamer463's Avatar
mattthegamer463 has yet to learn the way of the Dremel
Oblivion keeps crashing
I just got The Elder Scrolls 4: Oblivion, and I have been having some little problems with it, and I just want to see what the community thinks. When I click the desktop icon, it opens the little selection screen, and I click "play game." Then it says "please insert disk", even though the disk is in. It gives me the option to cancel, try again, or continue. Try again causes the same error, but continue plays the game. If the disk isn't in though, the normal "Insert disk" message comes up. Also, every time I close the game after playing it takes a long time to close, then the program crashes. Its very strange. Does anyone else have these problems with their game? Thanks for the feedback!
OBLIVION RULES!
__________________
Latest Work: Boombox Build
Project PCB- Complete Digital Picture Frame 2.0- Complete
RumbleMouse - Complete Latest Project: TestPC- Complete
Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W
mattthegamer463 is offline   Reply With Quote
Old 6th Apr 2006, 08:46   #2
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
Never had this problem.
Maybe clean the laser or the disc.
Check for scratches and stuff on the disc.
DougEdey is offline   Reply With Quote
Old 6th Apr 2006, 09:14   #3
acron^
ePeen++;
acron^'s Avatar
acron^ has yet to learn the way of the Dremel
Some games [are n00b and] check for D:\ by default OR the drive you used to install the game. If you have multiple CD/DVD drives, make sure you're using the one you installed with or try D:\
__________________
rage | portfolio | email
XBL GamerTag: acron0
www.BlitzGamesStudios.co.uk
acron^ is offline   Reply With Quote
Old 6th Apr 2006, 09:55   #4
mookboy
BRAAAAAAP
mookboy's Avatar
mookboy has yet to learn the way of the Dremel
Disable virtual drives or anything like Daemon Tools too, also try running the game by inserting the disk first and starting from the options box that appears when it autoruns.
mookboy is offline   Reply With Quote
Old 6th Apr 2006, 11:14   #5
Mister_Tad
Serious about coffee
Moderator
Mister_Tad's Avatar
Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!Mister_Tad - it's over 9000!!!!!!!!1!1!1!!!
My optical drives are G and H and oblivion is quite happy with that so i dont think thats the case.
Do you have any virtual drives running? sometimes games arent especially happy with that.
Mister_Tad is offline   Reply With Quote
Old 6th Apr 2006, 19:00   #6
Veles
DUR HUR
Veles's Avatar
Veles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the Dremel
Mine does that, what I put it in my RW instead of my ROM it checks the F frive first and complains about it, I click ok and the game launches.
Had a couple of problems with the game popping up a error sending box when I exit the program, but as it's when I'm exiting anyway I don't care.
__________________
Veles on: Xbox Live (My Halo stats), Steam Community, Twitter
Originally Posted by Fod View Post
spam gangsters might as well tap into all those machines for their zombie networks.
Veles is offline   Reply With Quote
Old 6th Apr 2006, 19:09   #7
mattthegamer463
Mod Master
Yeah, its not a big problem for me, it just takes a while and its a nusance, so I was wondering if anyone knew how to fix it.
__________________
Old 6th Apr 2006, 22:29   #8
Bladestorm
Hypermodder
Bladestorm has yet to learn the way of the Dremel
I've not had any problems starting it, when exiting it usually errors, seemingly harmlessly (feels to me like its pretty much closed, but the exit command maybe comes slightly too fast before its actually finished so it pops up an error message, even though nothing may be technically wrong)
__________________
i5 2500k | EVGA GTX 260 55nm SSC | P67A-GD53(B3)| 8GB Corsair vengeance 1600 LP | Asus Xonar DX | Antec truepower new 650w | Akasa Eclipse-62 | Win7 ultimate
Bladestorm is offline   Reply With Quote
Old 6th Apr 2006, 22:54   #9
DougEdey
DougEdey's Avatar
According to a forum post from the devs, its a memory leak but since its not really causing harm they aren't gonna fix it till they fix the other bugs with some of the quests
Old 6th Apr 2006, 23:00   #10
Kaze22
Supermodder
Kaze22 has yet to learn the way of the Dremel
It's not the virtual drives. I have some virtual drives such as Daemon and Alcohol, and I never have the please insert disk error. Not even once, maybe you should try putting the disk in first then start the game. Because it takes the drive some time to load up the disk. As for the exit crash, it happens all the time, don't worry about it.
Kaze22 is offline   Reply With Quote
Old 9th Apr 2006, 02:40   #11
mattthegamer463
Mod Master
I simply eliminated this problem with a no-cd crack (don't tell anyone )
__________________
Old 11th Apr 2006, 10:25   #12
PA!N
Hypermodder
PA!N's Avatar
PA!N has yet to learn the way of the Dremel
I need some help guys, PLEAS...
I was playing oblivion yesterday and it suddenly crashed:I saw a bluescreen for less than a second and then my pc rebooted. At first I thought it was just a regular crash that I had a few times before, so I started oblivion again and as soon as I clicked on the "Load" buton I was thrown to the desktop. I tried it a few times always with the same result so I tried to load my last save game with the other button and I got an error message that made me freak:
The savegame your trying to load is version 0.00 the current gameversion is 1.25 some errors may occur. Continue loading? I clicked yes an I got a message that the savegame is damaged
Anybody know how to solve this problem? (I alreaddy reinstalled it...)
PA!N is offline   Reply With Quote
Old 11th Apr 2006, 10:31   #13
orb
satisfying.
orb's Avatar
orb has yet to learn the way of the Dremel
Play an older save, if you haven't got one, then restart is the only choice.
__________________
[ ADDICT ]
orb is offline   Reply With Quote
Old 11th Apr 2006, 10:45   #14
PA!N
Hypermodder
PA!N's Avatar
I alreaddy removed a couple of saves and then tryed the continue button but still I got the same problem...I totaly dont want to restart...
Old 11th Apr 2006, 10:54   #15
orb
satisfying.
orb's Avatar
I meant try an older save, like load an older save. I have over 190 saves, because of all the quests bugs in this game i save all the time just incase something goes wrong
__________________
[ ADDICT ]
Old 11th Apr 2006, 20:41   #16
speedfreek
Ultramodder
speedfreek's Avatar
speedfreek has yet to learn the way of the Dremel
I cd cracked the game and have no problems with it, well sometimes it crashes when closing. My friend had a problem with it crashing when he looted what he killed but he repaired an ini file and it works great.
__________________
Q6600 | HD5870xxxUBERversion | 6gb of RAM | Several TBs of hdd
now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem.
Laptop: HP EliteBook, its fast!
speedfreek is offline   Reply With Quote
Old 11th Apr 2006, 20:46   #17
PA!N
Hypermodder
PA!N's Avatar
Thats what I did but since the game crashes when I hit the Load butten (ergo I cant select any saves) I removed some of my about 700 saves (I saved very often cause the came crashed a lot ) and then used the button to load the last...
Old 11th Apr 2006, 20:51   #18
orb
satisfying.
orb's Avatar
What happens if you press continue?
__________________
[ ADDICT ]
Old 11th Apr 2006, 21:28   #19
PA!N
Hypermodder
PA!N's Avatar
I get a message sayin' :
That is extremly wired because I didnt do anything withe the game...it just crashed and after a reboot I startet to bi*** like this
Old 11th Apr 2006, 23:13   #20
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has yet to learn the way of the DremelFirehed has yet to learn the way of the DremelFirehed has yet to learn the way of the Dremel
I'm guessing that it was writing to the file when it crashed, and farked up the file. I'm guessing you can't do a whole lot to fix it. Especially as savegames aren't straight text, but some freaky encoded crap as most games are (oh, the days of mudding).
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Reply
Tags
pc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
